beocords reel-to-reel - discussion. tell what you want
This post has 11 Replies | 1 Follower
Kopfnuss
Posts 18
Kopfnuss Posted: Mon, Jan 20 2020 9:28 PM
I bought a Beocord 2400 1/2 track reel-to-reel tape recorder with 1/4 track switch almost three years ago. in the course of time i bought two more to restore it with the spare parts. the mechanics was not a problem, but in the end I had to give it to a workshop because the cables and boards were too much for me :-D
maybe i will get it restored in january 2020. up to this point I have only heard bluetooth through the line in. nothing directly about tape. i never made it to a recording. was just tinkering and moaning.
I'm 31 years old and I don't even know anything like that from my childhood.
I would like to start a discussion with this to learn more about this old technology, especially beocords.
can you upgrade such a device to high-end?
heads, or even the hardware? is there something like 24bit / 192khz? how do you maintain your tape recorder regularly?
I am very enthusiastic about such old technology and am really looking forward to my first recording.
Søren Mexico
Mexico City
Posts 6,353
First of all, most of us dont upgrade to anything but original, your Beocord was state of the art when it came out, at that time near studio equipment.
If your tone heads are ok they will probably last for some more year, if worn they mostly can be restored. most important things is to keep the recorder clean, mechanics lubricated and well adjusted according to manual. Get yourself a new set of belts,and dont use or buy old tapes, buy good quality new ones.
Your recorder is analog and it will never be digital so 24 bit and 192 khz is not an option, but it will record and playback almost anything between 20 and 18000 Hz with a tape speed at 19 cm/sec. I have a Beocord 2000 and a Beocord 1200
politician
Posts 125
I managed to pick up a mint condition, fully operational Beocord 1200 complete with rubber caps and dust cover on eBay for £105. Not a device I use very often, but it has stunning looks and great sound quality.
Steffen
Denmark
Posts 1,359
Steffen replied on Tue, Jan 21 2020 2:59 PM
As Søren already wrote: Those old Beocords were high-end when they were manufactured back then.
And they can be high-end again - (analogue, offcourse - forget about bits and bytes Wink ) -when carefully restored.
As Søren wrote: new belts, some lubrication -and maybe some new caps (capacitors).
The famous producer Jeff Lynne (ELO), who has been producer for Traveling Wilbury's, George Harrison, Paul McCartney, Tom Petty and many more, started his career with a Beocord 2000 Deluxe:
"Some time in or after 1965, he acquired his first item of studio recording equipment, a Bang & Olufsen 'Beocord 2000 De Luxe' stereo reel-to-reel tape recorder, which allowed multi-tracking between left and right channels. He says it "taught me how to be a producer".
http://www.radioswisspop.ch/en/music-database/musician/9210119db9c8c7ad69b05381fd380fce0f4e3d/biography
Kopfnuss
Posts 18
Kopfnuss replied on Tue, Jan 21 2020 7:48 PM
The mechanic saw the situation with the capacitors at the beginning and wanted to replace some of them.
The straps will also be new, the tape heads cleaned. I will let him show me all this in more detail.
I find the 20 - 18000 HZ interesting
It is clear to me that the tape can record more data and deliver better quality at higher speeds.
Can you modify the engine so that it runs faster and can achieve a higher HZ rate?
Would it make sense to replace these old boards one-to-one with new material?
what comes to mind! Are there still new slip clutches to buy?
I tortured myself a lot with the slip clutches.
Which tape material can you recommend?
I will listen to my 20 bit ELO album Discovery on my 16 bit bc9500 :-D
a great work by Jeff Lynne
Søren Mexico
Mexico City
Posts 6,353
Change all electrolytic capacitors and trimmers, if not bad now they will go bad eventually, there is no need to change all components on the PCBs,
Slip clotches, no new ones to buy, clean, lubricate and adjust according to manual, get new belts from Dillen on this forum, they are special made to specifications and comes with instructions
Tapes, I use these bought on Amazon US
RMG/EMTEC Studio Mastering Tape 911 Series 1/4 –Inch x 1200 Feet 7 - Inch
Jeff
USA
Posts 3,637
Silver Member
Jeff replied on Wed, Jan 22 2020 12:41 AM
I'm surprised no one has mentioned the tools you'll need to maintain things after it's up and running, mainly tape head cleaner, foam swabs for cleaning heads and the tape path, and a demagnetizer/degausser to periodically demagnetize the tape path/heads. Also, if you're going to ever splice tapes you'll need splicing tape and a tape splicing block and razor blades to do that.
Jeff
Kopfnuss
Posts 18
Kopfnuss replied on Thu, Jan 30 2020 6:49 PM
Thank you for your answers. I will probably not glue or cut tapes. the shot should already fit. I will look at the head cleaning and demagnetization again on youtube. I will talk to the mechanic for maintenance and care. I thank you for all the advice and good tips.
because of the band. In theory, I would have to choose a manufacturer or a type of tape and have the device measured accordingly. Does it matter, which coil you take? I can imagine that one or the other spool is thicker than the other and the tape is a little higher, or is that wrong? I would like to pack everything on aluminum. for the optics.
the RMG / EMTEC Studio Mastering Tape 911 Series 1/4 - Inch x 1200 Feet 7 - Inch-TAPE is quite short. I have a MAXELL UD 35-90 with 1800 feet.
thought the MAXELL would be perfect, but maybe the tapes with less length are better because they may be a bit thicker and can hold more "data"?
the mechanic received a similar tape from MAXELL from me. I can still ask him to adjust the machine to a different belt. studio mastering sounds really good: D
The maxell is often available to be welded in, but I always have my concerns, because it could still have been near magnetic objects. I know that from my vhs cassettes. Some used ones are so bad, but they were not often looked at. any old films.
for the purpose of new tapes I will read a little more on the internet.
Questions about questions, but I can't find anything about a difference in the height of the coils on the Internet.
I'm slowly getting ready for my tape recorder.
Thank you all so far.
Andrew
Frinton, UK
Posts 829
Silver Member
Andrew replied on Fri, Jan 31 2020 10:23 AM
Hi - I have a four reel to reel tape recorders and in my experience:
  • The thicker the tape the less length but it is stronger - this is important as one of my old Akai machines can break tapes when you move from rewind to play too quickly or stop - there is most likely a fault in the braking mechanism which is doing this.
  • All old machines will develop problems at some point, even if they are restored as the mechanics and electronics are all old and even when they were new, due to the complexity they could have problems. A lot will depend on it's histiory and how it was used. A studio Revox will have had more use than a home machine but will most probably have been serviced. Of course some go on for years and years without needing anything.
  • The speed at which you run the tape will have the biggest difference on sound quality - the faster the better the quality, slower speeds are good for voice and recoding plays off the radio or language teaching. I use a ferrograph on the slowest speed for recording Amateur Radio sometimes. And a Philips for learning French (purely out of nostalgia from school days)
  • Demagnetizing the heads is easy - plenty on uTube and nothing to worry about. If you are using old tapes then you will need to clean the heads more often. Don't forget to clean the whole tape path including the guides, pinch wheel roller and erase head - Ispopropyl is good for that task - and wait for it to dry.
  • Tape Head alignment can be a problem if you start messing with them - usually they have been aligned and have a red spot of paint on the screws, if you start trying to realign then you risk things like when you turn the tape onto the other side hearing the background noise from the other side backwards! I would leave that to an expert as you can make it sound like its better only to find you have another problem.
  • Some have independant motors for each spool and others use one motor with a belt drive. The motors can need lubricating which reduces noise and belts can need replacement - this can be tricky but take your time and see if there is a video on YouTube to show you how to do it.
  • Avoid using really old tapes as they can break and leave a mess on your machine
  • Take everything slowly - if something is stuck it is usually dried up grease, degrease and carefully re-grease it. If you get fed up trying to solve a problem, search the internet, look at youtube and leave the machine alone whilst you figure out what the problem is. Better to fix it properly once than create more problems.
Reel to Reel tape recorders though are great fun to use, listen too and watch while the reels go round. In some ways CD's recorded onto tape, particularly music from before the 1970's sounds better to me on reel to reel as it introduces that analogue sound.
I'm sure you will have years of enjoyment with reel to reel and wish you well with it.
Andrew
Frinton, UK
Posts 829
Silver Member
Andrew replied on Fri, Jan 31 2020 10:26 AM
By the way - does anyone know if  the B&O reel to reels based on Tandberg machines as the play and rewind controls look very similar? I beleive the Tandbergs were very good and reliable so wouldn't be surprised if B&O used their transports - but of course I could be totally wrong - interesting to know.
Dillen
Copenhagen / Denmark
Posts 11,266
Dillen replied on Fri, Jan 31 2020 10:46 AM
Andrew:
They are not.
They were competitors up to the point where Tandberg started producing decks with electronic control, digital ICs, relays and solenoids, and B&O backed out.
Andrew
Frinton, UK
Posts 829
Silver Member
Andrew replied on Fri, Jan 31 2020 4:32 PM
Thanks Dillen - that had been bugging me for ages as I always thought they were as the control looked so similar.
Page 1 of 1 (12 items) | RSS
