Beovision 8 with Beo4 remote HDMI problems
Not Answered This post has 0 verified answers | 6 Replies | 1 Follower
VwSherbert
VwSherbert posted on Sun, Jan 12 2020 10:55 PM
Maybe my last post went. adrift, so I'll try again.
Basically I have a Beovision 8-32 and I'm try to connect up a HDMI DVD player.. I've gone to connections in the menu and assigned AV1 as DVD and source HDMI and saved my settings... I can't find a way for the source to be shown on the TV.. do I need to assign something to the channels, or assign the source settings to the Remote.. Any help for a B&O dummy would be much appreciated.
Many thanks
Millemissen
Flensborg, Denmark
(If configured that way) you simply push the DVD button on your Beo4.
The rest must be done with the original remote from the DVD-player (except for volume up/down).
No DVD button on the Beo4? Please ask again!
VwSherbert
Hi, thanks for the quick reply..
Unfortunately there is no DVD button on the remote.
I've got following layout:
TV / Light / Radio
Sat / AV / CD
V Tape / Record / A Tape
is the remote too old for my requirements?
Millemissen
Flensborg, Denmark
Well, I thought that that might be the ‘problem’!
Older Beo4’s are from before the era of the DVD - at that time there was an optical media for video called CDV, which had a softbutton on these remotes.
The "CDV"-command on the Mk1-Beo4 is identical to the "DVD"-button on the later Beo4 versions.
The "CDV" command however, needs to be added and can be accesed via the "List" button.
How the "add" a command: Press "LIST" and "standby" simultaniously, then scroll with list until "ADD" is displayed, then press go and scroll until "CDV" is shown on the display. Then press "GO" and the display should indicate "ADDED".
Now you should be able to access the "CDV" command and open the port you have configured for the DVD player.
Alternatively - get a ‘newer’ Beo4.
VwSherbert
Thanks MM,
I'll give that a try when I get home today..
Thank you very much for the quick and well explained help and suggestions
kind regards
VwSherbert
Hi MM,
it work... thank you for the help!
with kind regards
Millemissen
Flensborg, Denmark
VwSherbert:
Hi MM,
with kind regards
Glad to have helped!
Enjoy your BV8
Page 1 of 1 (7 items) | RSS
