AIRPLAY OVER MULTIROOM
Not Answered This post has 0 verified answers | 29 Replies | 0 Followers
Alsfeld
Alsfeld posted on Sat, Jan 4 2020 5:57 PM
By accident I found the following page: https://support.bang-olufsen.com/hc/en-us/articles/115000942169-How-do-I-distribute-sound-from-AirPlay-over-Multiroom.
Unfortunately I do not find "APPLE" in the menu.
I can "push" airplay to selected NL products (e.g. Core), but I can not forward the stream via B&O Multiroom to another NL product (e.g Beosound 35).
I read the above link so, that this should be possible. But how?
steve1977
Jaffrey2230:
I agree, you can AirPlay 2 anything from an iOS device to any number of speakers without going through any B&O protocol. In my case if a B&O speaker does not have AirPlay built-in, I just make sure it is connected to an Apple TV (if connected to a TV) or an Apple AirPort Express. You can basically use any AirPlay 2 complaint streamer to do the trick. I also prefer the AirPlay 2/iOS user interface over the B&O App for multi-room. So, you only have a problem if you'd rather use the B&O App vs. Apple's user interface.
TV Room : BL 8000, BL 2 connected to 65 Inch Sony A1E OLED TV
Living Room : BL 6000, B&W PV1 connected to AirPort Express driven by AirPlay 2
Dining Room: BeoPlay A9 Mk2
Kitchen : BeoPlay P6
Bedroom : BL 6000, BL 11 connected to LG UST Projector and Apple TV 4K, room also has an Apple HomePod
Travel : BeoPlay H4 3rd gen.
2020 plans: Add a BeoSound 2 to the office and upgrade living room BL 6000 set with BL 18
My setup and intent is same / similar to yours. And i’m happy to be able to control this setup fully with AP2 (same as you do).
My comment was that a setup as the one above does not allow to “join” B&O devices by “tapping”. For example in the above setup, you cannot “join” the A9 by tapping. You can join the A9 through IOS, but not through a tap.
Jaffrey2230
Washington DC
True. It would save a step. However, with Siri you can use voice to move/add any speaker in any room quite easily. However, it requires an iOS or HomePod in voice range. Hopefully B&O can improve their app and software to the point where it is as refined as say SONOS. Until then, Chromecast with Google Voice or AirPlay 2 with Siri are probably the best options.
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
Millemissen
Flensborg, Denmark
Jaffrey2230:
If AP2 works for you, it might be the best option for you.
I guess if you are using AP2 to control your devices, you will have an iDevice in reach anyway!
Here is how to do this (using an iPhone):
https://youtu.be/joV_DdkJWWk
As for the very last part with the third party apps, this has changed or is about to change - it seems that Apple now (with iOS13) is more open for Siri controlling of non-Apple apps.
I think it would be best not to dream about the option for integrating a specific B&O/NL multiroom feature into the Apple eco system - that would require some heavy changes to how Apple does things.
Alsfeld
Alsfeld replied on Sun, Jan 19 2020 10:06 AM
I like this feature! Wondering how long B&O already is offering it.
In my setup I have made the experience that the synchronization is much better (no echo) when I stream to one speaker via Airplay and connect all other B&O speakers via B&O Multiroom.
Compared to connecting all B&O speakers directly to the streaming device via Airplay 2, in this case I have a very low delay (= small annoying echo) between the B&O speakers.
Do you have similar experiences?
So I am fighting with myself. Using only one app (e.g. Deezer), steaming via airplay 2, but having a low echo OR using two apps Deezer and the B&O app to group my B&O speakers.
Jaffrey2230
Washington DC
I have 2 Beolab sets connected to Apple TV’s, 2 to Airport Express, A9 and recent Beosound 2 with native AirPlay 2 support. I also have a strong Google wifi mesh. There is no delay. In fact I am so impressed with the way it works that I am thinking of ditching my Beoplay P6 altogether with a Beosound 1 as a portable speaker since it supports AirPlay 2 - just ordered it on Amazon!
Funny that in my case, getting the B&O App to play across multiple devices resulted in audio drop outs. Back in the day I bought two A6s for multi-room with an A9.  I ended up selling the A6 because the wireless didn’t work well with the B&O App. At the time, AirPlay 2 wasn’t out and the user experience wasn’t great. Now I have developed a new found love for my old and new B&O gear. 🙂
B&O in my life 😊:
Razlaw
Razlaw replied on Sun, Jan 19 2020 5:29 PM
Jaffrey2230:
Are you saying you have Apple TV’s connected directly to Beolabs with no television? I would be interested in connecting a pair of Beolab 4000s to an Apple TV but did not think that is possible.
Thanks!
Beolab 50s Beolab 9s Beolab 12-3s Beolab 1s Beolab 6000s 2 pairs Beolab 4000s Beovision 7-55 Beovision 10-40 Beoplay V1 32 inch Beovision Avant 32 inch Beosound 1 (CD player) Beosound 3000 Beosound 5 Core Essence MKII Beoplay M5
Millemissen
Flensborg, Denmark
Alsfeld:
 .......OR using two apps Deezer and the B&O app to group my B&O speakers.
Why two apps?
Can’t you access Deezer from within the Bang & Olufsen app?
Alsfeld
Millemissen:
Why two apps?
Main reason I do not use the B&O App is, because it does not offer Deezer „FLOW“ and „Music by Mood“ at least I did not find it. But perhaps it is as hidden as the Airplay distribution feature?
In general in my eyes the B&O App interface to Deezer and to DLNA is much too limited to really use and enjoy it.
Millemissen
Flensborg, Denmark
I understand your reasons.
Personally I use the Spotify (Connect) app - even if it (with my setup/my devices) is pretty well integrated in the Bang & Olufsen app, I use two apps.
But I do not see, that as a problem!
When I use AirPlay, I use other apps too - e.g. if I want to listen to and distribute podcasts or I want to catch up on radio programmes, that I did not manage to listen to when they were originally aired.
Distributing AirPlay over the B&O multiroom has been supported for quite a long time.
This way I stay in the Bang & Olufsen app and can use the external/not integrated sources, whenever I need/prefer these.
With time you get a certain workflow - no big problems here.
Even if TuneIn and Spotify Connect are my main sources, I certainly would miss the possibility to distribute AP over B&O multiroom, if that was not possible.
P.S.
As for ‘FLOW/Music by Mood’......that is not the way I listen to (read: use) music - I am a dedicated album listener.
So, different user cases might call for different approaches to how you use your (B&O) gear.....and the app.
Jaffrey2230
Washington DC
I have both Apple TV’s connected to BeoLabs when connected to TVs and AirPort Express when not connected to a TV. The AirPort Express DAC is really good. You could use an Apple TV in headless mode without a TV for audio, but you’ll need an external DAC between the Apple TV and Beolab speaker.
B&O in my life 😊:
HH1971
HH1971 replied on Sun, Feb 16 2020 9:58 AM
Wow, it took me 15 minutes to find the described Airplay functions in the deep deep setup menus.
Very well hidden B&O!
Is this the Bang&Olufsen user experience to convince new customers to pay more money than for competitor products?
Where is the official Bang & Olufsen manual or website where I can find this kind of information and all new features offered over time?
But probably B&O is ashamed of the user experience they offer to their customers, so they decided to hide (and not to communicate) all available features and offer their speaker as cheap and simple Airplay / Chromecast alternatives as all competitors do.
Millemissen
Flensborg, Denmark
HH1971:
How do I distribute sound from AirPlay over Multiroom
It took me five seconds to get that information (asking Google for it) from B&O - first hit.
https://support.bang-olufsen.com/hc/da/articles/115000942169-How-do-I-distribute-sound-from-AirPlay-over-Multiroom
Not enabling this feature as the default one is a decision made because many users/buyers may prefer to use AP2 when they have other non-B&O AP2 devices in the setup.
As you can read in the link, AP over NL and AP2 distribution will not work well together.....
.....and - really - it did not take me 15 seconds to find that option ;-)
Carolpa
Carolpa replied on Sun, Feb 16 2020 12:40 PM
HH1971:
Exactly were it should be! Simply because it is not a setting used on a daily base
HH1971
HH1971 replied on Sun, Feb 23 2020 7:17 PM
Millemissen:
thanks for the link.
But the questions I still have:
1) where can I find the manual(s) that explains the complete set-up menu of my B&O equipment?
2) where can I find all new features of the software / app / firmware updates available?
(so that I do not need to follow / read all threads at this forum to get some overviews what technical features are available - when somebody by accident mention is or asking for)
But probably Bang&Olufsen is already in such a bad financial situation that there is not enough money to write a detailed manual and maintain an internet page to list and explain all software / firmware updates.
mm08642
Unfortunately B&O tradition / culture is to hide information / detailed description of features available from their customers.
I never understood why Bang&Olufsen is doing it.
I could imagine the following reasons:
  1. B&O thinks that they have very technical limited customers and they do not want to confuse them with too many technical information
  2. B&O want to foster their dealers, so that they are able to impress their customers
  3. B&O wants to save the money by not publishing PDF manuals
  4. B&O just does not care
Page 2 of 2 (30 items) < Previous 1 2 | RSS
