Taking on the BM8000
Not Answered This post has 0 verified answers | 19 Replies | 0 Followers
krais
The Netherlands
krais posted on Sat, Dec 28 2019 11:56 AM
Hi all,
I've recently started restoring an old BM 8000 (type 1901) that I bought second hand years ago. The seller told me that the BM would not turn on (repeatedly clicking relays). I did not try to power the unit up to avoid blowing the output stages so not sure what the actual symptoms are.
After not being able to find a B&O technician in the Netherlands that is willing to take on a BM8000 due to the labor involved I decided to have a go at it myself. I know, I know, these are complicated amplifiers, not really stuff for an inexperienced hobbyist with little knowledge of electronics... I just cannot resist the challenge so decided to give it a try with the help of information available online (beolover website).
Any help along the way would be appreciated. I love this design so would be awesome to get it working again (or at least take care of the laborious tasks such as recapping and rebuilding the LED displays).
sonavor
Texas, United States
Replace the insulators with new mica insulators and grease. You can opt for sil pads instead of the mica/grease insulators if you want. I have restored using both methods without any problems. I just wouldn't re-use the old insulators at this point on yours.
-sonavor
Beo_Jean
QC, Canada
Beo_Jean replied on Sat, Jan 11 2020 10:34 PM
Good choice on the Nichicons, I like them!
Personally, I'm using thermal pads instead of the micas, much cleaner work and one versus the other, a matter of preference.  Now, if you had multiple layers of mica, I would give the edge to the pad for heat dissipation performance.
I'm also concerned about the cooking PCB.  Mounting the resistors with a gap from the PCB is a good practice if you have clearance on top.  Consider adding cooling for that transistor that seems to suffer from heat too!
Dillen
Copenhagen / Denmark
Dillen replied on Sun, Jan 12 2020 7:44 AM
"Also, I swapped the 0.5W resistors for 1W carbon film versions to alleviate some of the heat issues"
The same amount of energy will be dissipated, regardless ot the components wattage range.
You could do as Jean suggests and lift the resistors a milimeter off the board, though it's usually not a problem - unless completely burned - in which case something else will most likely be amiss too.
Lifting components without fitting some kind of relief under them puts stress on their solder joints, which must now carry
the components weight - "upwards".
The lifted components will easily be pressed down, forcing the solder pads from the board. Vibrations will also be much higher and will eventually cause cracking to the solder joints.
Using radial capacitors instead of axials will also do something like that. Why not use axials?
krais
The Netherlands
krais replied on Tue, Jan 14 2020 8:43 AM
Thanks for the great feedback all, I have ordered new mica insulators and will finish the output boards when they arrive.
Dillen:
Yes, indeed the resisters are raised slightly from the board.
Dillen:
Good to know, I will be more mindful of minimizing vibrations when replacing components. I'll see if I can add some stress reliefs here and there (on the radial caps for example).
Dillen:
The reason I used radial capacitors for C205/C211 is that I couldn't find axial capacitors with -10%+50% tolerance as specified in the service manual. Maybe this is not a strict requirement?
Dillen
Dillen replied on Tue, Jan 14 2020 10:10 AM
krais:
It's not that critical. 20% tolerance caps will be fine.
Page 2 of 2 (20 items) < Previous 1 2 | RSS
