Beosound 9000 - how to clean laser
Answered (Not Verified) This post has 0 verified answers | 9 Replies | 2 Followers
chrisdv
chrisdv posted on Sun, Dec 8 2019 6:24 AM
My Beosound 9000 was not used for 2 years and the CDs aren't playing. I read on this forum that it could just be dust and that Test Mode 65 will allow me to move the laser out and clean it, but I can't figure out how to put it in Test Mode. Mine is certainly not a Mark III.
How would you get it in test mode on Mark 1 or 2?
Thanks,
Chris
Peter
Siemianowice Sl., Poland
ONLINE
Peter replied on Mon, Dec 9 2019 9:53 AM
Generally to enter test mode the unit has to be disconnected from mains. Then you connect it, wait 20-30 sec, put the unit in Option 1, and start test mode: SHIFT90258 then you press CD and enter mode numer.  Not sure if it works on Mark I but please try.
israrsalter
Peter:
Generally to enter test mode the unit has to be disconnected from mains. Then you connect it, wait 20-30 sec, put the unit in Option 1, and start test mode: SHIFT90258 then you press CD and enter mode numer.  Not sure if it works on Mark I but please try. valentines day gifts for her
Thank you very much!! Very useful advice
chrisdv
chrisdv replied on Wed, Dec 25 2019 10:39 AM
Thanks, Peter. I couldn't figure out how to get mine in test mode, so I assume it doesn't exist on Mark I. I bought a disk with small embedded brushes. The challenge I had is that the player wouldn't rotate the disk since it couldn't focus (I assume). I finally got it to work by manually rotating the disk, which cleaned the laser sufficiently to start focusing and then run the disk autonomously. It works fine now.
Beobuddy
Utrecht, The Netherlands
Beobuddy replied on Wed, Dec 25 2019 11:49 AM
The sequence works for every model.
Make sure that RADIO or CD shows in your BEO4 display when you enter the numbers.
chrisdv
chrisdv replied on Thu, Dec 26 2019 11:24 AM
Thanks, Beobuddy. I couldn't get it to work, even though I followed the general directions. Shift is the "Back" button on the remote, right? And is the number code the same for Mark I, II and III?
Appreciate the help.
chrisdv
Peter
ONLINE
Peter replied on Fri, Dec 27 2019 9:15 AM
Chris,
you have to add SHIFT command to LIST buton of Beo4. Then you chose that command and press OK.
mija
Answered (Not Verified) mija replied on Fri, Dec 27 2019 11:57 AM
Suggested by mija
The other point that is often overlooked is the sensors: the 2 half-moon sensors and the 2 transparent raised ones.
Before trying anything else just clean them (with a bit of isopropyl alcohol), they tend to be sensitive to dust.
On my BeoSound 9000 I have to clean them on a regular basis (because of the open fire).
If it doens't work, then just proceed to the test mode to clean the laser (I did it a long time ago and it worked)
Good luck
Michel
Beobuddy
This is not needed to get the BS9000 in testmode.
First thing (when speakers are not connected to the BS9000 directly) is to set the BS9000 in A option 1. The standby led has to blink once to confirm the command. If it doesn't respond, then it might be a faulty infrared receiver.
After the BS9000 confirms the Aopt 1, it will go in testmode.
Page 1 of 1 (10 items) | RSS
