Hi guys, I received my besound moment few months ago but I was in the middle of relocating for good. So yesterday, I unboxed everything ( from dealer ) and to my surprise the screen has clouding and light bleeding on the edge.
Attached some pictures for your reference. Is there anything I can do about it? Is this even normal or does it qualify for repair ?
I bought a BeoSound Moment.
It was a moment of madness.
Would you please elaborate?
I have two Moments; one does this, while the other does not. I moved the one with the bleeding to the office where I never operate in the dark. With room lights turned on it is not at all noticeable, so I haven't concerned myself further.
Sources: 2x Beosound Moment • 4x Beosound Essence Mk IISpeakers: 3x Beolab 8000 • 1x Beolab 6000 • 1x Beolab 3 • 3x Beolab 2 • 4x BeoPlay M5 • 1x BeoPlay A6Control: 9x Essence Remote • 1x Beoremote Halo
BV Eclipse 55 Brass - BL 18 Brass - BL 19 Brass - BL17 Black - BL 3 White - BS Moment - BS 2 Brass - BV Horizon 48 - BS3000 - BS 3200 - BS Essence MK2 - BL 4000 - V1 40 Black - V1 40 White - BLC NL/ML - H6 - H4 - E8 Motion - A8 Earphone - Beolit 12 - Beolit 15 - Beoplay A1 Green - Beoplay A3 White
Hello,
Dealer was able to replace my beosound moment. Now I have a bigger issue. I can't get it to work. I tried resetting and restarting but I'm getting the following issue although I have a working internet connection both through WIFI and LAN.
