Beovision 7 external speakers
Answered (Not Verified) This post has 0 verified answers | 8 Replies | 1 Follower
joniamh
joniamh posted on Mon, Dec 2 2019 12:08 PM
Hi All,
I am new to the site and B&O as you can see below Big Smile, I did have a quick look to see if anyone had posted this question before.
Basically I have just brought a second hand beovision 7 off ebay, and now I need to purchase some speakers for it.  My question is the would a pair of BeoLab 4 speakers work with the TV. I just wanted to make sure i made the correct chose. If so it is an easy setup.  As setting the tv up last night took me an age.
I do have some more questions about steaming Tv but I guess lots have asked these questions so will read up now.
My TV is a  Beovision 7 type 9344. If you need anything more please let me know.
Many Thanks
Millemissen
Flensborg, Denmark
If your BL4’s are the version with PowerLink connections, it is pretty easy to set them up with that tv.....as are all PL-based speakers.
Have you had a look in the user guide of the speakers and/or the tv?
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Hi joniamh,
Welcome to Beoworld!  Yes, both versions of Beolab 4 (ie. with and without 8 pin Powerlink sockets) will work perfectly with your TV, also any other Beolab speakers can also be used.
This cable set will connect a set of Beolab 4PC speakers (without Powerlink sockets) to the TV: https://soundsheavenly.com/beolab-4-and-4pc/29-131-powerlink-to-beolab-4pc-set-of-two-cables.html#/2-length-1m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
joniamh
Thanks Steve,
joniamh
Thanks Steve, the above image is from the back showing the connections. Power link center the same as power link ?  Thanks Paul
Hi Paul,
If you have other Powerlink sockets on the TV (possibly under the other cover), then please use those instead.  If you just have the two centre Powerlink sockets, then they can be used.
Steve.
joniamh
Hi Steve and thanks for the help.  under the other cover I dont have any power link sockets.  Just the attached.  Do I revert to your initial answer.  Thanks Paul
Hi Paul,
This panel shows a full set of Powerlink sockets on the left of your image.  The cable I mentioned will connect to the Front or Centre Powerlink sockets on this panel.
Steve.
joniamh
Thanks again Steve.
Page 1 of 1 (9 items) | RSS
