Beosound 5 Encore - Sound delay on Aux input
Not Answered This post has 0 verified answers | 8 Replies | 2 Followers
ClaudeCAT
France
ClaudeCAT posted on Mon, Dec 2 2019 11:41 AM
Hello,
I've connected my Tv headphones output (not B&O) on Aux input BO 5 Encore. My goal is to watch concerts or movies with Beolab 8000 quality sound. Each input of BO 5 Encore works well, but then I use Aux input, there is a significant sound delay (almost 0.5s) compare to TV sound. Therefore, image and sound are not synchronized and it's really significant.
First, I thought delay was on hearphones ouput, resulting D to A transformation. I checked it with another sound system and it works well, no delay at all. TV sound and hearphones output are totally same.
After that, I thought reason was cable lenght betwen TV and BO 5 encore, so I checked with a shorter cable but result was identical. Transmission delay from 5 Encore to loudspeaker cables is non significant.
So, I deduce 5 Encore apply a delay, wich I don't understand why. Logically, analog signal must be pre-amplified without D to A conversion (instead of another inputs) so no delay must be apply. I haven't service manual with diagram to confirm that and I have no idea of how fix it.
My question : is it a BO 5 encore known problem ? In case of, is there a solution to reduce this delay ?
Thx for your help. Regards.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Hi ClaudeCAT,
Welcome to Beoworld!  Unfortunately, it is not possible to remove the delay within Beosound 5 Encore - this product is not suitable for connecting to a TV.  If your TV has a headphone socket fitted, you may be able to connect the speakers to the TV instead and link the Encore into the TV - please let me know if this is of interest and I can advise further.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
ClaudeCAT
France
Hi Steve,
Thank you for your answer, and of course I'm interested by your advices. A Line input exist in Beolab 8000, more Powerlink. But if I connect my TV' headphones output directly to Lab 8000, I have to select sound entry manually by switching between Left, Right and Line. So, if I use Line input, I'll cannot easily use both sound from Beosound 5 Encore (for listening my music library or radio) and Tv sound (for concerts) as I want, until you explain me your trick to do that.
My TV own only HDMI inputs, USB input, Y/Pb/Pr + Left/Right input and Ethernet.
What do you think of using an RCA/Powerlink adaptator (for Tv headphones output) and link headphones output with Beosound 5 Encore output using an Y powerlink adapter ? If I switch on my TV, do you think sound signal is enought powerful to switch on both Beolab 8000 ? I don't know but I suppose Beosound 5 Encore send a signal on a powerlink pin to swtich on or off Beolab, so I wonder if what I say is possible without damage...
Thx for your advices,
Best regards, Claude.
marexy
Slovenia
Hi
It's the same problem with BS5+ BM5 !
As i did try to find some way not to be sound delay ...it is not possible or i can't find way.
I use Berhinger for AUX- USB input and i can not find any other option.
Hi marexy,
For Beomaster 5, there is a solution! Cool (although this doesn't work for the Encore):-
If you connect a TV to Beomaster 5 via the USB adapter, there will be a delay to the audio from the TV, so that it will not match the picture (this delay occurs within the Beomaster 5 and it is a known issue with B&O).  The only solution to this is to buy a Beolink Converter from Bang & Olufsen (type 1161166) and connect this to the Beomaster 5 with a Masterlink cable: https://soundsheavenly.com/21-link-systems
You can then use the headphone output into the B&O converter with this cable:-
https://soundsheavenly.com/bang-olufsen/67-298-minijack-to-aux-in-ipod-to-beosound-beomaster-beocenter-using-aux-din-socket.html#/2-length-1m
Please note that this may switch off the TV speakers and that you will need to set the TV volume quite high, typically 75% of maximum.
You can then listen to the TV through the Beomaster 5 without an audio delay by pressing “TV” on your B&O remote control.
Steve.
ClaudeCAT
France
I found this product Bosscom Powerlink switch on https://powmascables.com/contents/nl/d97_Bosscom-Powerlink-Switch.html#p98
I think it's exactly what iI want to do when I look diagram (https://powmascables.com/PDF/Powerlinkswitch/PLairplay.pdf) but it's very expensive. With an RCA/Pwlink adapter, pin 4 is not link, which is logical.
So, goal is to send 5-15v on pin 4 to activate Beolab 8000 when sound is present on pins 3 and 5. Someone has an idea ?
lechatsurletoit
I have this setup, and TV will play on every speakers connected to my Masterlink network except the ones connected to the beomaster 5 itself, 2xBL8000s via a powerlink.
When I press on the TV button (beo4) , BM shuts down and the converter acts as a Master. If I turn back on the BM5 it will play whatever is selected, but not the TV output that is still playing in the other rooms.
lechatsurletoit
Check Almando also
marexy
Slovenia
marexy replied on Tue, Dec 3 2019 11:19 AM
Thanks Steve :)
will try that ..as i have one beoilink converter extra :)
from that i can see thar only problem on delay is conversion from analog to usb.
As i have BS9000 connected to other TV with cheap 5 USD china DAC optical to analog and it no delay.
Page 1 of 1 (9 items) | RSS
