BeoVision Eclipse Service Menu
Not Answered This post has 0 verified answers | 10 Replies | 3 Followers
kmortenesi
kmortenesi posted on Sat, Nov 23 2019 9:10 PM
Does anyone know how to enter the LG service menu on an Eclipse? I need to change the Region as I have moved from EU to US. I tried using the LG service remote, but it doesn’t react at all. Stuck...
w5bno123
London
w5bno123 replied on Sun, Nov 24 2019 10:10 PM
Does it not change automatically due to your IP address, assuming your not using a VPN to dial back to the EU?
Mikipidia
Can you not just reset it? Then you’ll go through setup again and you can set your location and such
New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0
mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
kmortenesi
Resetting will take you through selecting your country, but region is not something you pick as far as I know? It does not automatically select a new region based on IP address etc.
I have actually got the LG remote to work (by removing the grill) so now I just need to find the LG code that allows me to access service menu. It’s not the typical LG code
w5bno123
London
w5bno123 replied on Sun, Nov 24 2019 11:48 PM
You can use the BR1 to do this as well.
https://www.my-private-network.co.uk/kbhome/changing-lg-service-country-region-on-lg-tv-webos/
kmortenesi
Thanks but the link only shows how to change country, not region
kmortenesi
Problem solved: remove speaker grill and the LG service remote works. Found the proper region code and all is well
eeiciap
eeiciap replied on Sun, Jun 21 2020 12:01 PM
Hello,
Just came across this thread. I'm also looking to enter the LG service menu to change the region on my Eclipse.
Is someone able to provide a step-by-step guide? I've tried searching online to no avail.
kmortenesi
You need a LG service Remote control. I bought mine on Amazon. Then you remove the Eclipse grill. When you enter the service menu it prompts you for a code. It’s 1925. You can then make your changes. Which region do you want to change it to? US is 22282
eeiciap
Thanks for the quick response! I just bought a service remote and will try it out. I'm trying to change it to US.
kmortenesi
Ok. Please use the region code I listed above (from the Eclipse manual). Let me know if you have trouble and I can help
Page 1 of 1 (11 items) | RSS
