Beolab 2
Not Answered This post has 0 verified answers | 13 Replies | 1 Follower
bramble
bramble posted on Tue, Nov 19 2019 4:41 PM
Can a beolab 2 be placed within a unit were there is only the front driver showing. It's placement is not tight against the sub there is about 2-3 inch on all sides.......
Possible location off were bl2 would sit
Rgds
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
bramble
bramble
bramble
Will see how it works out....[:\'(]
DMacri
United States
DMacri replied on Tue, Nov 19 2019 6:13 PM
It will probably work, but the narrow spaces on the sides might act like slot loading and impact the sound somewhat. Try it out and see if you think the sound is degraded.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, and ambio
BOBrb
BOBrb replied on Tue, Nov 19 2019 7:50 PM
That's pretty much the worst thing you can do with the speaker. He should stand 60-80cm away from all objects. But try it out. Men in Black is well suited.
Millemissen
Flensborg, Denmark
I would not do that either.
Looking forward to your results.
Jaffrey2230
Washington DC
Probably won’t make a difference for a sub since the sound is not supposed to be localized. The side passive radiators as far as I know have no bearing on the sound quality. I have a BL2 and it basically a boomy sub good for movies. So this placement should be fine. My two cents worth.
bramble
Thanks for all our advice.... I am still trying it in its new location.
It may be my old ears but I can't tell any difference in sound, I just wouldn't want to damage it.
TWG
TWG replied on Thu, Nov 21 2019 7:35 AM
For a normal constructed subwoofer with one or two forward facing speaker chassis it could work somehow but for Beolab 2 with the passive radiators I doubt that it'll work (and sound) good.
Please just try it out and let us know if you are happy with the result.
Rob - Danish AV
Melbourne
There is only 1 driver firing from the front. The sides just need a bit of airflow. If you leave it there, perhaps keep the power of it a bit lower..
bramble
OK peeps,
After listening to movies and audio (vinyl & cd/Spotify ) I can say there is no difference in sound, I have turned down the input/setting and put it in corner setting via switch.
The sub is set quite low anyway so not to destroy the neighbourhood.
I will continue with it in its current position.. Unless advised of potential damage!
Or if any sound guru's from b&o could advise
bramble
Just played sting " Englishman in new York " very heavy bass intro, sound exactly the same as if bl2 was in a more open area in the lounge.
1. No sound differences ( apart from lowering bass setting)
2. No distortion
3. And is working as should, no sudden faults have appeared.
So will live with it .......thanks all for all your input please feel free to give any further info / comments .
AdamS
AdamS replied on Fri, Nov 22 2019 2:14 PM
My take is that it might well make the Beolab 2 sound boomy and horrible.
However, given that I've always thought the Beolab 2 was boomy and horrible anyway - you've got nothing to lose!! Big Smile
Page 1 of 1 (14 items) | RSS
