Connect BeoCom 2 to Fritzbox or DECT Basis
Not Answered This post has 0 verified answers | 8 Replies | 0 Followers
Tim84
Munich
Tim84 posted on Mon, Nov 18 2019 5:40 PM
Hello,
I just got an old BeoCom 2 from my parants but as I only have a Fritzbox as DECT Basis I want to connect the BeoCom2 to this router.
Is there a way or Code to activate the Connection mode on BeoCom 2?
My BeoCom has the following data:
- Hs sw. ver. 0049 -1.5-1 / 200111071230
- Serial 15978187
- IPEI: 00506 / 0110752 0
Current System
  • Livingroom: BeoVision 7 MKV + BL7-2 + 2xBL 8000 + BL 2 + 2x BL 4000; BeoSound Ouverture
  • Bedroom: BV 7-32 MKIV / BL7-1
  • Kitchen: BeoPlay M3
  • Bathroom: BeoPlay M3
  • Entrance: BeoPlay M3
Tim84
Munich
Tim84 replied on Wed, Nov 20 2019 12:24 PM
Googeling quite some time now.
is there no way to put beocom 2 into a pairing Mode?
Current System
Millemissen
Flensborg, Denmark
Es gibt eine deutsche Benutzer Guide auf der Homepage von B&O:
https://www.bang-olufsen.com/~/mediaV3/files/user-guides/beocom2/beocom2_getstarted_german.pdf
Was gemacht errden muss beim Fritzbox geht aus der Bedienungsanleitung des Box’s hervor (es gibt auch Videos dazu auf YT.
Sollte nich allzu schwierig sein.
Tim84
Munich
Tim84 replied on Fri, Nov 22 2019 3:59 PM
Hello MM,
thanks for your answer. Unfortunately this doesn't work with my BeoCom. May this beacuse it is a MK I device?
regards  Tim
Current System
Siggi
Siggi replied on Fri, Nov 22 2019 6:57 PM
thats possible....the mk1 could only work with bang&olufsen Basic stations.only dealer could pair them.
Greetings
Millemissen
Flensborg, Denmark
Thanks Siggi,
very important information for those who would like to own a BeoCom 2.
Anyone knows how to spot the difference between the two versions....serial number etc?
OldJack
Split
You can spot difference
https://www.beoworld.org/faq_view.asp?id=94
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones A8,A9 keyring,Bottle opener,Wine SetT(thanks botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,Beoplay A1,Oppo udp-203, LinTronic.
Millemissen
Flensborg, Denmark
Great, thanks!
TWG
TWG replied on Sat, Nov 23 2019 10:07 AM
another note:
It was possible to upgrade MK1 Beocom 2 to newer software by the dealer, so they could used in standard DECT infrastructures like the MK2, too.
Don't know if the dealers are still able to upgrade MK1 to MK2 in 2019?
Page 1 of 1 (9 items) | RSS
