Setting the clock on the Beolab 3500
Answered (Verified) This post has 1 verified answer | 3 Replies | 1 Follower
Thomas
Louisiana USA
Thomas posted on Sat, Nov 16 2019 2:02 PM
I have read the user manuals for the 9500, 3500, and the Beolink 1000 and cannot find a way to set the correct time on the BL 3500 clock.
I set the internal clock on the 9500 as it said to do.  The Remote does not mention how to set clocks. The 3500 tells you how to set it to Timer, No Timer, Clock 1 and Clock 2, but not how to actually change the time itself.
Does anyone here know how to do this?  Seems like there has to be a way to change a digital clock on anything.
Thomas
Beobuddy
Utrecht, The Netherlands
Verified by Thomas
Setting the time at the BL3500 isn't possible. It should be received from the BC9500 or any other master with MCL which has the option to set time.
I would try to disconnect the BL3500. Set the time properly in the BC9500. Then connect both. It can take some time to synchronize, but it should be synchronized.
Beobuddy
Verified by Thomas
Thomas
Louisiana USA
Thomas replied on Mon, Nov 18 2019 7:38 PM
Thank you.  I will try that.
Thomas
Louisiana USA
Thomas replied on Tue, Nov 19 2019 8:45 PM
I did just what you said to do and it came out exactly like you said it would.
It worked and is slowly syncing up.   I am very grateful to you for your help.
Thank you!
Page 1 of 1 (4 items) | RSS
