Beolab 8000 and Beomaster 3500/4500
Not Answered This post has 0 verified answers | 4 Replies | 2 Followers
kimasker
kimasker posted on Thu, Nov 14 2019 10:35 PM
I have two Beolab 8000 and are thinking of connecting them to a Beomaster 3500/4500.
Can I just use the Power Link cables/connectors for this or ?
Millemissen
Flensborg, Denmark
Yes, that is how it is done!
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Hi kimasker,
Welcome to Beoworld!  Yes, you just need two Powerlink cables like these: https://soundsheavenly.com/powerlink-8-pin-din-connection/20-272-powerlink-mk-3-compatible-8-pin-din-cable-with-4-cores-wired-low-profile-cable.html#/9-length-18m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
kimasker
Hi Steve,
Thanks, why not use the Powerlink mk2 and avoid any nose?
Kind regalds,
Kim
Hi Kim,
My mk3 and mk2 cables are both wired correctly to avoid noise.  The mk3 cables are thinner and cheaper, without losing any sound quality.
Steve.
Page 1 of 1 (5 items) | RSS
