Beolink Gateway BLGW vs. Beolink Converter NL/ML BLC NL/ML
Answered (Not Verified) This post has 0 verified answers | 11 Replies | 6 Followers
kallasr
Germany
kallasr posted on Thu, Nov 14 2019 1:43 PM
Since they look the same, can you change their purpose by uploading firmware?
Here is the BLGW:
And here an older version of the BLC NL/ML:
And the latest Version of the BLC NL/ML:
I want to play with a BLGW to see how the Beosound 5 can be controlled via iPad App Beolink 2.
Instead of buying a used BLGW I could temporarily turn a spare BLC NL/ML into a BLGW - that is my idea behind the question...
Thanks for your Input!
Ralf
kallasr
Germany
Any ideas / hints for me?
Ralf
Carolpa
kallasr:
Here is the BLGW:
Ralf
Ralf
both BLC are exactly the same. Just strip away the plastics strips on the BLC without AUX. You'll see the AUX connections are present.
Same on the other side of this BLC
Note: even the BLGW have them!
kallasr
Germany
kallasr replied on Tue, Jan 28 2020 12:16 PM
Thanks. I thought so About the BLCs, too.
But how about the Beolink Gateway?
It does look the same as well. So only a Software issue e.g. you Can Change a converter to a Gateway (and vice versa)?
Ralf
Carolpa
kallasr:
Ralf
Living Room: Beosystem 4, Beolab 7-6 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), no Subwoofer. Screen: Panasonic TX-P65STW60 Home Cinema: Beosystem 4, Beolab 7-2 (Center), Beolab Penta 2 (Fronts), Beolab 4000 (Rears) and Beolab 2. Projector: Sony VPL-HW55 Home Office: Beovision 10-40 on STB Bracket wall mount masterlinked to Beosound 9000 MK3 on horizontal wall bracket driving Beolab 5000 Speakers Bedroom: Loewe TV with Beolab 6002 and Beolab 11 (all white, wall-mounted) In storage: Beolab 5000/Beomaster 5000 (1960s).
presumably the same! But how to get hold of the blgw software??
Carolpa
Carolpa:
Addition: Not only present in the first generation BLC, but also in working order (PL, AUX, IR)
huwtec
Wales
Answered (Not Verified) huwtec replied on Wed, Jan 29 2020 5:34 PM
Suggested by huwtec
Hi Ralf
I do not know if this answers you'r question but I once bought a BLGW at a discount from a dealer because it was a BLC NL/ML body with BLGW software on it. The dealer had received it that way from B&O and had intended to sent it back to B&O but then sold it to me as I was looking for a used BLGW. The problem I had with it was that the software would not update, and after contacting B&O they told me that it would not update as it was essentially a BLC NL/ML. I sent it back to the dealer in the end and the dealer sold me a new BLGW at a good discount.
Hope this helps
Huw
ebnrob
UK
kallasr:
Hi Ralf, were you able to find a way to change the firmware? I found the latest firmware for the BLGW online, just need a way to upload it to the NL/ML converter! Rob.
kallasr
Germany
You refer to the file 1.4.0.20048-signed.bin.zip?
I got this as well but never tried to upgrade the spare converter...
Bought a used MLGW but was not satified so I gave up on B&O home Automation for now.
Ralf
ebnrob
UK
ebnrob replied on Fri, Jun 5 2020 10:50 AM
Hi Ralf, I am thinking of getting a used MLGW too, what is it you don't like about it? Regards, Rob.
TWG
Answered (Not Verified) TWG replied on Tue, Jun 9 2020 12:21 PM
Suggested by Gianni
ebnrob:
I'm using a MLGW with HUE lights and without the help of some really smart guys from this forum and the Philips HUE API tutorials, I wouldn't have been able to make it do what I want. So I guess that's the no. 1 reason against a MLGW: The work you need to put into it to get out what you want. (HTTP JSON commands etc.).
But when you're done and it works it's much easier and faster than using any smartphone or tablet + app. I just press e.g. Light and yellow on my Beo 4 and all the lights for this scene are on. With a Beo 5 / 6 it's more family compatible as you can rename everything the way you want.
You can't beat that compared to fiddling around with your smartphone. ;-)
The BLGW seems to make automation life much more easier. I can't judge for myself as I only use MLGW.
Tim84
Munich
Tim84 replied on Tue, Jan 11 2022 7:31 PM
ebnrob:
kallasr:
is there already a solutions to upload the BLGW Firmware to a NL/ML Converter? I have one spare and would love to experiment with a BLGW.
Living room: BeoVision 7 MKV + BeoLab 7-2 + 2x BeoLab 8000 + BeoLab 2 + 2x BeoLab 4000
Office / guest room: BV 7-32 MKIV / BL7-1; BeoSound Core + Turntable
Kitchen: BeoPlay M3
Bathroom: Gira Radio + BeoLab Celestial
Entrance: BeoPlay M3
Page 1 of 1 (12 items) | RSS
