Beovision 7 DVI not responding
Not Answered This post has 0 verified answers | 9 Replies | 1 Follower
Stevenlowry
Stevenlowry posted on Tue, Nov 12 2019 8:27 PM
Hi guys I was wondering whether someone could help me.. I have a mk3 I think.. It's a 9334... ive been told it's HD ready so I should be able to work my Apple TV over it and audio over airplay.. However I just can't seem to get anywhere with it..
I have a beo4 remote...
Can someone help me please... how do I get my Apple TV on.. Ive connected it using a HDMI to dvi but can't seem to get to a dvi source...
Please please help me.. I love the way the tv looks but it's extremely annoying!
9 LEE
Eastbourne, UK
9 LEE replied on Tue, Nov 12 2019 8:50 PM
Your Apple TV is probably set to 1080p output.
The BV7-32 is 720p so it can't show a 1080p image as it doesn't have enough pixels and the scaler can't handle it.
Smile
Stevenlowry
Thanks Lee for responding so quickly... I have tried to reset the resolution which works I believe.
I'm struggling to get onto the right source.. And the remote and menus seem to be extremely difficult to use.. Unless I'm just being an idiot
Thanks in advance
Stevenlowry
I reset the resolution of the Apple TV out still can't seem to get the picture. When I press av on the remote should it bring up anything? How do I get it to the dvi source?
Thanks in advance
9 LEE
Eastbourne, UK
9 LEE replied on Wed, Nov 13 2019 11:52 AM
You need to assign DVI-I to the source in the BV7 set-up menu. Smile
Stevenlowry
Lee sorry for being a complete retard... how do I do that?
9 LEE
Eastbourne, UK
9 LEE replied on Wed, Nov 13 2019 12:29 PM
MENU - SETUP - SOURCES - then choose DVI-I.
The user / setup manual is on here if you'd like to upgrade to Silver and support the site :)
Lee
Stevenlowry
Is that on the remote or the tv.. I don't have an option for set up on the tv..
If I click tv on the remote and then menu it comes up with other options not setup...
Appreciate all the help mate
Stevenlowry
I gets options to change connections
Stevenlowry
I gets options to change connections.. But that just confuses the he'll out of me... And I'd like to think I'm quite savvy
Page 1 of 1 (10 items) | RSS
