Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Good evenind,
That looks like a failing amplifier board on the speaker.
See https://forum.beoworld.org/forums/t/37951.aspx
The solution is either to find and replace the defective MOSFET transistor (a DIY repair) or to replace the board. B&O still has them in stock.
Regards,
Jean
If you only chage only MOSFET you did not repair it or maybe yes in 10% ..for short time.
Tweeter is OK.
Problem is on power amp. PCB or crosower PCB.
Where are you from ?
Marexy hi, I live in Edinburgh...
You can repair it or buy new power amp board.
