Beolab 4000 and WISA
Not Answered This post has 0 verified answers | 4 Replies | 1 Follower
Tassos
Athens
Tassos posted on Tue, Nov 5 2019 7:04 AM
Hello all,
I have been looking for a way to upgrade my surround speakers from a pair of CX100 driven from an ML/MCL converter to something more contemporary and potent. I already have a pair of Beolab 4000 which I really love and I think they would fit nicely (not only sound-wise) to my set-up.
So the idea is that I install into the casing of the Beolab 4000 a Beolab receiver 1 and turn the 4000 into a wisa speaker so I don't need to run new cables through the walls. Does anyone know the pin-out of the transformer of the receiver? The cable ends to an rj11.
Thanks a lot
Tasos
Rob - Danish AV
Melbourne
Sounds like a messy job. Why not just split the power cable from the wall to the 4000? you will reduce signal strength having it inside the 4000 cabinet
Jaardo
Jaardo replied on Sat, Apr 3 2021 12:09 AM
I just tried to connect a Beolab Receiver 1 to my Beolab 4000, and it unfortunately does not work. Can't explain why... 😔
kuyttendaele
Jaardo:
What is it connected to?
kuyttendaele
Tassos:
Hello all,
Thanks a lot
Tasos
I would not fit a Receiver 1 into a BL4000. It would block too much of the signal.
Page 1 of 1 (5 items) | RSS
