Where is TURN function on Beoremote1 ?
Not Answered This post has 0 verified answers | 10 Replies | 1 Follower
Silou
Switzerland
Silou posted on Sat, Oct 12 2019 5:01 PM
all is in the Title ! ;-)
Razlaw
Razlaw replied on Sat, Oct 12 2019 5:13 PM
Do you mean for a motorized stand? If so, the command is Stand.
Beolab 50s Beolab 9s Beolab 12-3s Beolab 1s Beolab 6000s 2 pairs Beolab 4000s Beovision 7-55 Beovision 10-40 Beoplay V1 32 inch Beovision Avant 32 inch Beosound 1 (CD player) Beosound 3000 Beosound 5 Core Essence MKII Beoplay M5
Silou
Switzerland
Silou replied on Sat, Oct 12 2019 5:16 PM
no TURN for ATAPE (K7)
beojeff
USA
beojeff replied on Sat, Oct 12 2019 11:17 PM
If you can't find it, it's available as a command on the BLGW to map to one of the "CONTROL" commands on the BeoRemote One.
trackbeo
The Beo4 manual says that TURN is accomplished by pressing the center button (a.k.a. GO).  Maybe that works on the BeoRemote One too? Seems unlikely I admit -- sorry, I don't have my old equipment available to test, so I'm just guessing...  Presumably you have already tried P+ and P- as well as the backarrow (<--, a.k.a. BACK, left of INFO) and none of them worked?
Silou
Switzerland
Silou replied on Fri, Oct 18 2019 10:09 AM
Not found. But not check every Control. List is too long...
@ beojeff I don't have any BLGW
Guy
Buckinghamshire
Guy replied on Fri, Oct 18 2019 4:33 PM
Not sure if it helps, but on the BL1000 TURN is achieved by pressing SHIFT then SOUND.  I don't have one, but perhaps you can get the BeoRemote One to do this?
Silou
Switzerland
Silou replied on Sat, Oct 19 2019 7:53 AM
Guy:
Unfortunately no SHIFT on BR1...Sad
trackbeo
trackbeo replied on Sat, Oct 19 2019 11:32 PM
Yes, there is a SHIFT function, but it's on the "LIST for Beo4 Video" (if you enable it in the menus), not the one for Beo4 Audio.  Whether or not it can be used to change the following button-press if you have to access said button-press from the LIST button again as you must to get "Sound", who knows?
Trivium: The *reason* TURN was overlaid on SHIFT-SOUND when it was removed from the remotes was because the other function of the TURN button (besides flip-the-cassette) was to switch between sound tracks on a video tape or a multi-language TV tuner program in Beovision MV/VX 5000 days.
[Edit: Have you tried enabling the "Track" menu item in the Beo4 Audio List?  If I were an engineer, that's where I'd hide it: Track-1 and Track-2 is what the cassette (virtually) is, after all...  Yes, I know that *should* be the same as P+ and P- buttons, but since we're grasping at straws, there's another one to try!  Again sorry I cannot test myself instead of posting WAGs.  Your question has become a bee in my bonnet, because I bought a BeoRemote One BT to replace a dead Beolink 1000, so I'm gonna send a web-form message to B&O support, too.]
trackbeo
B&O Support says, "The 'Turn' command is unavailable on the BeoRemote One as it is simply outside of its capabilities."
Silou
Switzerland
Silou replied on Thu, Oct 24 2019 6:45 AM
trackbeo:
Big SmileBig Smile but in fact CryingAngry Beo become a farce !
Page 1 of 1 (11 items) | RSS
