Hi everyone,
I am new to the forums and I am with a company called Axiim. We make WiSA products that work with Bang & Olufsen loudspeakers. I have seen a few discussions about the new WiSA Ready LG TVs and I was wondering if anyone had any questions about the new standard?
Thank you and I look forward to our discussion!
Hammej:Hi everyone, I am new to the forums and I am with a company called Axiim. We make WiSA products that work with Bang & Olufsen loudspeakers. I have seen a few discussions about the new WiSA Ready LG TVs and I was wondering if anyone had any questions about the new standard? Thank you and I look forward to our discussion!
Vince, you need to purchase a WiSA USB transmitter like the Axiim LINK. You can find more details at following websites.
https://axiim.com/pages/axiim-link
https://www.wisaassociation.org/member-products/wisa-usb-transmitters/
When you plug the WiSA certified USB transmitter into the LG TV it will prompt you if you want to setup WiSA speakers. You simply follow the on-screen speaker setup to pair your B&O WiSA speakers. The LG TV will decode Dolby and DTS audio formats and send the discrete audio channels to the 5.1 locations so NO external AV receiver is required for decoding.
There are some significant difference between the Axiim LINK and WiSA USB transmitter. The WiSA USB transmitter does NOT support bass management and audio mixing so you will only get 2.0 or 5.1 audio. This means if you have a subwoofer it will not play audio for music or two channel encoded content. You will have a similar issue with not receiving center channel audio with 5.1 content if you have a 4.0/4.1 speaker configuration. This means you will not hear the dialog in movies or music when a center speaker is not paired. So please keep this in mind when purchasing.
LINK support bass management, audio mixing, per speaker volume trim, firmware update, and more.
I hope this was helpful.
-James
Vince, attached is a comparison chart between LINK and the WiSA USB transmitter.
I have a pair of BL8000, which are not Wisa ready. I use them as rear speakers and I would lile to eliminate the cables.
Is there a Wisa receiver I could use?
Dante,
I believe you are looking for the BeoLab Reciever 1,
https://www.bang-olufsen.com/en/collection/apps-and-accessories/beolab-reciever-1
What are you using for your front main speakers and TV?
BL5 as front speakers, BL5 as surround and BL8000 as rear, BL10 as center.
My current TV is a old Panasonic, but I'm planning to replace it with a LG soon and eliminate my Beosystem 3.
You will need to have BL Receiver 1 for each speaker to work with the WiSA Ready LG TV. Also, please note that the LG TVs only support 2.0 and 5.1 channels of audio at the moment. If you want to support 7.1 you will need to buy an Axiim Q or other WiSA transmitter.
Hammej:Vince, you need to purchase a WiSA USB transmitter like the Axiim LINK. You can find more details at following websites. https://axiim.com/pages/axiim-link https://www.wisaassociation.org/member-products/wisa-usb-transmitters/ When you plug the WiSA certified USB transmitter into the LG TV it will prompt you if you want to setup WiSA speakers. You simply follow the on-screen speaker setup to pair your B&O WiSA speakers. The LG TV will decode Dolby and DTS audio formats and send the discrete audio channels to the 5.1 locations so NO external AV receiver is required for decoding. There are some significant difference between the Axiim LINK and WiSA USB transmitter. The WiSA USB transmitter does NOT support bass management and audio mixing so you will only get 2.0 or 5.1 audio. This means if you have a subwoofer it will not play audio for music or two channel encoded content. You will have a similar issue with not receiving center channel audio with 5.1 content if you have a 4.0/4.1 speaker configuration. This means you will not hear the dialog in movies or music when a center speaker is not paired. So please keep this in mind when purchasing. LINK support bass management, audio mixing, per speaker volume trim, firmware update, and more. I hope this was helpful. -James
New: Beolab 50's, Beolab 18's, Beolab 17's, Beovision eclipse, Beosound 9000 mk3, Beosound 1 Bronze edition, Beoplay M3, Beoplay A1.
Mikipedia on YouTube (finally )
https://www.youtube.com/c/Mikipedia
Old: Beolab 1's, beolab 2, beovision 10-46, overture 2300, beolab 8000's, beolab 4000's, beovision avant 32" etc. etc.
Vince,
1. The Axiim LINK has a DSP to perform the audio functions like bass management, EQ, audio mixing, etc.
2. The LG TV only allows you to use WiSA Ready or the TV speakers but not at the same time. Also, honestly you wouldn't want to use the LG as a center because the quality is nowhere near the performance of the B&O speakers.
An alternative is you can buy an Axiim WM5211CS center channel and we have many customers that do this.
3. This is a great question. I'm not sure if ARC works while WiSA Ready is enabled. I will check today and see.
Thank you,
James
Yes, LINK supports 5.0 configuration and will redirect the content to the main L/R channels.
Hammej:Vince, 1. The Axiim LINK has a DSP to perform the audio functions like bass management, EQ, audio mixing, etc. 2. The LG TV only allows you to use WiSA Ready or the TV speakers but not at the same time. Also, honestly you wouldn't want to use the LG as a center because the quality is nowhere near the performance of the B&O speakers. An alternative is you can buy an Axiim WM5211CS center channel and we have many customers that do this. 3. This is a great question. I'm not sure if ARC works while WiSA Ready is enabled. I will check today and see. Thank you, James
I just checked and the LG TV requires you choose between the WiSA and ARC so you can't have them both on at the same time.
Hammej:Vince, I just checked and the LG TV requires you choose between the WiSA and ARC so you can't have them both on at the same time. -James
Right now the only LG is the only TV certified as "WiSA Ready". It's a great start but we definitely would like to see more TV manufacturers on board. In the mean time you can use the Axiim Q UHD Media Center with any TV. Here is a link,
https://axiim.com
Hammej:Right now the only LG is the only TV certified as "WiSA Ready". It's a great start but we definitely would like to see more TV manufacturers on board. In the mean time you can use the Axiim Q UHD Media Center with any TV. Here is a link, https://axiim.com Thank you, James
Hello! I was wondering if by using a Wisa transmitter, like de aciim link, through the Lg Oled via bitstream, is it possible to have lossless sound?
Hi
I just managed to get an Axiim Link WISA Transmitter - combined with a LG C9 TV and some Beolab speakers. I started another thread to gain and share some experiences here:
https://forum.beoworld.org/forums/t/38671.aspx
Please do step in if you have any knowledge to share or questions
Best regards
gd61
