New WiSA Ready Standard - 2019 LG OLED and NanoCell TVs
This post has 22 Replies | 2 Followers
Hammej
Posts 11
Hammej Posted: Tue, Oct 8 2019 7:17 PM
Hi everyone,
I am new to the forums and I am with a company called Axiim. We make WiSA products that work with Bang & Olufsen loudspeakers. I have seen a few discussions about the new WiSA Ready LG TVs and I was wondering if anyone had any questions about the new standard?
Thank you and I look forward to our discussion!
vlohjr1
Posts 441
vlohjr1 replied on Tue, Oct 8 2019 8:53 PM
Hammej:
Hi everyone,
Absolutely thanks for mentioning this
If I have an oled LG c9 panel how do I connect to my front and rear Beolab 18s wirelessly. I presume I still need an av receiver for cinema sound?
Thanks for your help
Vince
Hammej
Posts 11
Hammej replied on Tue, Oct 8 2019 11:58 PM
Vince, you need to purchase a WiSA USB transmitter like the Axiim LINK. You can find more details at following websites.
https://axiim.com/pages/axiim-link
https://www.wisaassociation.org/member-products/wisa-usb-transmitters/
When you plug the WiSA certified USB transmitter into the LG TV it will prompt you if you want to setup WiSA speakers. You simply follow the on-screen speaker setup to pair your B&O WiSA speakers. The LG TV will decode Dolby and DTS audio formats and send the discrete audio channels to the 5.1 locations so NO external AV receiver is required for decoding.
There are some significant difference between the Axiim LINK and WiSA USB transmitter. The WiSA USB transmitter does NOT support bass management and audio mixing so you will only get 2.0 or 5.1 audio. This means if you have a subwoofer it will not play audio for music or two channel encoded content. You will have a similar issue with not receiving center channel audio with 5.1 content if you have a 4.0/4.1 speaker configuration. This means you will not hear the dialog in movies or music when a center speaker is not paired. So please keep this in mind when purchasing.
LINK support bass management, audio mixing, per speaker volume trim, firmware update, and more.
I hope this was helpful.
-James
Hammej
Posts 11
Vince, attached is a comparison chart between LINK and the WiSA USB transmitter.
-James
Dante
Sao Paulo - Brazil
Posts 141
Silver Member
Dante replied on Wed, Oct 9 2019 12:54 AM
I have a pair of BL8000, which are not Wisa ready. I use them as rear speakers and I would lile to eliminate the cables.
Is there a Wisa receiver I could use?
Hammej
Posts 11
Hammej replied on Wed, Oct 9 2019 1:01 AM
Dante,
I believe you are looking for the BeoLab Reciever 1,
https://www.bang-olufsen.com/en/collection/apps-and-accessories/beolab-reciever-1
What are you using for your front main speakers and TV?
-James
Dante
Sao Paulo - Brazil
Posts 141
Silver Member
Dante replied on Wed, Oct 9 2019 1:40 AM
BL5 as front speakers, BL5 as surround and BL8000 as rear, BL10 as center.
My current TV is a old Panasonic, but I'm planning to replace it with a LG soon and eliminate my Beosystem 3.
Hammej
Posts 11
Hammej replied on Wed, Oct 9 2019 2:22 AM
Dante,
You will need to have BL Receiver 1 for each speaker to work with the WiSA Ready LG TV. Also, please note that the LG TVs only support 2.0 and 5.1 channels of audio at the moment. If you want to support 7.1 you will need to buy an Axiim Q or other WiSA transmitter.
-James
vlohjr1
Posts 441
vlohjr1 replied on Wed, Oct 9 2019 7:46 AM
Hammej:
-James
Thank you James. To clarify
1. Is Axiim link is a DSP per se?
2. Can Axiim can detect 5.1 using LG tv speaker as centre speaker in addition to my BL18s?
3. Can Axiim LINK work with beosound stage as centre speaker (arc to LG tv) and wisa to the BL18s?
Vince
pauliander
Posts 55
I have been told that the receiver 1 would not work with BL5. Therefore my question: Is there a solution for BL5 users and Wisa?
Mikipidia
Posts 1,129
Steve @ soundsheavenly has a solution for the lab 5, they need a fully seated pl but there is a work around.
With lg and wisa the tv’s own speakers will not work. It’s an either / or situation. The bs stage will have too much latency to work as a center from line in like this, so that won’t work.
New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beosound 9000 mk3, Beosound 1 Bronze edition, Beoplay M3, Beoplay A1.
Mikipedia on YouTube (finally Stick out tongue )
https://www.youtube.com/c/Mikipedia
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Hammej
Posts 11
Hammej replied on Wed, Oct 9 2019 4:13 PM
Vince,
1. The Axiim LINK has a DSP to perform the audio functions like bass management, EQ, audio mixing, etc.
2. The LG TV only allows you to use WiSA Ready or the TV speakers but not at the same time. Also, honestly you wouldn't want to use the LG as a center because the quality is nowhere near the performance of the B&O speakers.
An alternative is you can buy an Axiim WM5211CS center channel and we have many customers that do this.
3. This is a great question. I'm not sure if ARC works while WiSA Ready is enabled. I will check today and see.
Thank you,
James
pauliander
Posts 55
LINK supports bass management, audio mixing, etc. Will this allow a redirecting of the subwoofer channel to the front speakers (Beolab 5 contain subwoofers)? In other words does LINK support the set-up of a 5.0 system?
Hammej
Posts 11
Hammej replied on Wed, Oct 9 2019 6:51 PM
Yes, LINK supports 5.0 configuration and will redirect the content to the main L/R channels.
vlohjr1
Posts 441
vlohjr1 replied on Thu, Oct 10 2019 6:03 PM
Hammej:
Vince,
Thank you,
James
Hi James any further info on the last point thanks
Hammej
Posts 11
Hammej replied on Fri, Oct 11 2019 4:14 AM
Vince,
I just checked and the LG TV requires you choose between the WiSA and ARC so you can't have them both on at the same time.
-James
steve1977
Posts 777
steve1977 replied on Fri, Oct 11 2019 4:59 PM
Hammej:
Vince,
-James
Are there other TVs that would allow me to use wisa with your solution, while at the same time allowing to use either the tv speaker as center or the b&o stage?
Thanks!
Hammej
Posts 11
Hammej replied on Sat, Oct 12 2019 3:01 PM
Right now the only LG is the only TV certified as "WiSA Ready". It's a great start but we definitely would like to see more TV manufacturers on board. In the mean time you can use the Axiim Q UHD Media Center with any TV. Here is a link,
https://axiim.com
Thank you,
James
vlohjr1
Posts 441
vlohjr1 replied on Sat, Oct 12 2019 3:34 PM
Hammej:
https://axiim.com
Thank you,
James
Hi James would this be compatible with the BO sound stage?
Vince
Sandyb
Posts 1,595
Sandyb replied on Sat, Oct 12 2019 4:51 PM
Unfortunately not
oscarpena1511
Posts 1
Hello! I was wondering if by using a Wisa transmitter, like de aciim link, through the Lg Oled via bitstream, is it possible to have lossless sound?
Mikipidia
Posts 1,129
Mikipidia replied on Sat, Oct 19 2019 6:51 PM
Wisa is limited to 24 bit 96khz, the rest of the chain i don’t know but i suspect can do the same. Atleast the e-arc port can do that i guessSmile
gd61
Posts 5
gd61 replied on Wed, Dec 4 2019 3:01 PM
Hi
I just managed to get an Axiim Link WISA Transmitter - combined with a LG C9 TV and some Beolab speakers. I started another thread to gain and share some experiences here:
https://forum.beoworld.org/forums/t/38671.aspx
Please do step in if you have any knowledge to share or questions
Best regards
gd61
Page 1 of 1 (23 items) | RSS
