Beoplay S8 Connection Hub
Not Answered This post has 0 verified answers | 7 Replies | 0 Followers
Poly
Poly posted on Mon, Oct 7 2019 7:30 PM
Hello fellow b&o'ers :)
I recently bought and set up a pair of Beoplay S8's in my living room, and while I'm impressed with the sound I'm less impressed with the connection hub. Whenever the speakers switch to stand-by the connection hub makes this horrible and quite loud hissing noise. I called the b&o dealer whom I purchased the speakers from and he told me I had to send it in for repairs (I would have to go 2-3 weeks without it, so without being able to use my speakers) which really bugs me as they were quite expensive and brand new out-the-box (this issue was there from the beginning). I was really hoping someone could come up with a possible solution :) Note that I wont be able to switch the line-in as I'm running them on a non-b&o tv (hence the connection hub). Thanks in advance and kind regards Magnus
___
___ replied on Wed, Oct 9 2019 3:40 PM
All units has that damn noise Sad
Esax
Esax replied on Wed, Oct 9 2019 3:43 PM
That’s why I sold mine.
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Poly
Poly replied on Wed, Oct 9 2019 9:55 PM
Really? It's unbearable and the noise is really loud :-( I called the store a few weeks ago and he said that they would "tweak it" (the connection hub) when/if I sent it in for repairs, but basically what you're saying is that that it would most likely not really change anything at all?
Poly
Poly
Poly replied on Wed, Oct 9 2019 9:56 PM
Did you try and contact the b&o store you bought it from? And if so what did they tell you? Surely it has to be their problem since you've got warranty for at least two years
Saint Beogrowler
Saint Paul
Mine does the same thing. So annoying.
Poly
Poly replied on Fri, Nov 29 2019 6:33 PM
Update: After 4 (almost 5) weeks after creating an RMA I just received a brand new Connection Hub today, and it has the same high pitching beeping noise as the old one....
Page 1 of 1 (8 items) | RSS
