Issue with AppleTV after upgrade to tvOS 13
Answered (Not Verified) This post has 0 verified answers | 57 Replies | 4 Followers
ibg001
ibg001 posted on Sun, Sep 29 2019 6:36 PM
After upgrade of my Apple TV HD to iOS 13 my BeoVision 8 will no longer turn on the Apple TV.
If I turn on my Apple TV with the Apple Remote then I can use BeoRemote One to navigate on the Apple TV. So it is not a cable issue. It only turn on and turn off that does not work.
Any ideas?
Millemissen
Flensborg, Denmark
Indeed it is!
Reto
Zurich
Reto replied on Wed, Oct 2 2019 4:58 PM
Sounds great, but: I downloaded the new OS13 Version. But same behaviour as with the 'old' version.  Still to push the green button.
Anyone successfull?
Millemissen
Flensborg, Denmark
‘downloaded’, yes - but did you also assign it to your box....instead of the old one?
Reto
Zurich
Reto replied on Wed, Oct 2 2019 5:19 PM
Yes, I Did. I'm running the Apple TV behind an Atlona AT-HD4-V41 Switch. Could that be the problem? Setup should be ok. When I choose the source, the correct name of the (new) driver is shown on the TV. Everything seems to be ok. But still I have to push the green button.
ibg001
The green button do nothing at all.
My setup is a BV8 40 so I cannot download a new PUC table. So one day I need get it updated by a B&o technician.
kuyttendaele
Did the update... works perfectly again.
Reto
Zurich
Reto replied on Wed, Oct 2 2019 7:58 PM
Do you have a 4k box? Could that be the difference? I updated as well but nothing changed. Does switch off work?
expoman
Is there an upgraded puc for Beosystem 3  systems?
kuyttendaele:
expoman
kuyttendaele:
kuyttendaele
Reto:
The AppleTV is directly connected to my BV14. It's starting up and switching off correctly.
Karel.
kuyttendaele
expoman:
kuyttendaele:
Probably... but you'll have to contact your dealer as I don't have a BeoSystem3
Reto
Zurich
Reto replied on Thu, Oct 3 2019 8:39 AM
Thank you very much for your feedback. Are you running ATV4 (4K) or NON 4K.
Reto
kuyttendaele
Reto:
Reto
Running tvOS13 on Apple TV 4K.
Karel.
Reto
Zurich
Reto replied on Thu, Oct 3 2019 10:48 AM
Is there anyone successfully running the new PUC code (OS13) on a NON 4K device?
beojeff
USA
I updated the PUC and reassigned it on my BeoSystem 4 and I'm still needing to press the green button to wake the Apple TV from sleep. I have 2 Apple TVs: the most recent non-4K Apple TV connected via an Atlona Matrix and a 4K Apple TV that connects the video directly to the TV with the sound extracted to go to the BeoSystem 4.
Does it make a difference what we select on the BeoSystem 4 for the power on/off setting? I'm using the "always on" setting for the Apple TV.
Page 2 of 4 (58 items) < Previous 1 2 3 4 Next > | RSS
