Restoring a Beocenter 8000 (EEPROM)
Not Answered This post has 0 verified answers | 5 Replies | 1 Follower
Marwal91
Marwal91 posted on Mon, Sep 16 2019 3:39 PM
Hi !
I received a Beocenter 8000 from a friend that worked fine and then stopped working (no red dot when i plug it, no responding command no "clic" sound BUT the CD laser head is initializing... ) So i guess the problem is from EEPROM (someone told me it could be the point) so i'm looking for help to replace the EEPROM but i need to know more about it. I know that EEPROM is a memory that erase when you plug out the mains. But i know that there is a program inside the EEPROM... So is it working with a battery ? If i replace the EEPROM do i have to replace a battery too?
Thanks for your lights about it !
Dillen
Copenhagen / Denmark
Dillen replied on Mon, Sep 16 2019 9:35 PM
Check the power supply.
Check for cracked solder joints at the large filter capacitors and at the relay.
Marwal91
Hi thank you for your help ... My technical English is very poor as a French guy ... So could you be more precise about the parts I have to check ? Maybe if you can send me a picture or a technical drawing about the parts to check that really would help me !! :-) thank you very much !!
matador43
Dillen:
Vérifiez l'alimentation principale (avec un voltmètre…)
Dillen:
Vérifiez les soudures au niveau des gros condensateurs et du relais, Elles ne doivent pas être craquelées ou "sèche".
Dillen:
Martin.
Marwal91
Merci  !!  Thumbs Up
Dillen
Dillen replied on Tue, Sep 17 2019 4:51 PM
Det siger jeg også. Laughing
Page 1 of 1 (6 items) | RSS
