I'm lazily looking for the quickest way to get some information I need... and I suspect that the solution lies here in BeoWorld...
The setup:
My questions:
Thanks for your help!
-geoff
What's a BeoMaster 9000?
Beomaster 8000 (without capitol m) has 0.0-6.0 with a step size of 0.1
80s bm5000 was 0 to 6 iirc
Ban boring signatures!
Hi Martin,
Oops... two mistakes in one name! "BeoMaster" out of Habit and "9000" because I'm typing too fast and relying on copy/paste too much...
But thanks for your answer. That's a start...
chEers-geOff
Using Beolink 5000, the volume scale on my BC9500 is 0 to 98 with a step size of 2
Guy: Using Beolink 5000, the volume scale on my BC9500 is 0 to 98 with a step size of 2
Ooooh! Cool! A new one that I didn't know about!
Thanks!- g
Beomaster 6500: 0-78, steps 2.
Beomaster 5000: 0.0 - 6.0 steps 0.2
My 1975 Beomaster 6000 (quadraphonic) has touch switches and mechanical controls, and the volume range runs from 0 to 12.
BeoSound 4000: volume reads 00-72, increments by 2 .
This info is great! Thanks!
I'll start making a spreadsheet with the info...
Cheers-g
Geoff Martin: Guy:Using Beolink 5000, the volume scale on my BC9500 is 0 to 98 with a step size of 2 Ooooh! Cool! A new one that I didn't know about!
But does the BeoCenter 9500 actually play different volume levels for all those steps on the remote? There are only 38 presses from no-bars to max-bars using its front panel. Oddly, the number of presses needed to go from one bar to the next is 3 for the lower levels, but only 2 for the higher ones! (Excluding the first of course, 1 press from no bars to one bar.)
EDIT: It's actually 39 presses -- you can "turn it up to eleven", because the last press is invisible (max bars +1 level, only obvious when you go backwards). Why 39 Steps? Maybe the engineer was an Alfred Hitchcock fan...
trackbeo: Geoff Martin: Guy:Using Beolink 5000, the volume scale on my BC9500 is 0 to 98 with a step size of 2 Ooooh! Cool! A new one that I didn't know about! But does the BeoCenter 9500 actually play different volume levels for all those steps on the remote? There are only 38 presses from no-bars to max-bars using its front panel. Oddly, the number of presses needed to go from one bar to the next is 3 for the lower levels, but only 2 for the higher ones! (Excluding the first of course, 1 press from no bars to one bar.) EDIT: It's actually 39 presses -- you can "turn it up to eleven", because the last press is invisible (max bars +1 level, only obvious when you go backwards).
Interesting thread. Also of interest, in addition to how many steps/granularity of the control, what is the taper on all of them and is it mostly the same or not. From the above, it seems to be some kind of non-linear, log taper, which is normal for volume controls, but what is the taper? How did it change, if it did, was there a different design philosophy behind each system. Or did it depend on what the taper was of whatever component was used for the volume control?
Jeff
trackbeo: Guy:Using Beolink 5000, the volume scale on my BC9500 is 0 to 98 with a step size of 2 But does the BeoCenter 9500 actually play different volume levels for all those steps on the remote? There are only 38 presses
Double-check: The BeoLink 5000 will arrow-up from 0 to 98, but once it communicates status with the Beocenter 9500 after doing so, its display reverts to 78.
trackbeo: Double-check: The BeoLink 5000 will arrow-up from 0 to 98, but once it communicates status with the Beocenter 9500 after doing so, its display reverts to 78.
Oh yes, indeed it does! But perhaps that's the speaker overload protection cutting in? I will check the apparent volume tomorrow when the household is awake!
Jeff: Interesting thread. Also of interest, in addition to how many steps/granularity of the control, what is the taper on all of them and is it mostly the same or not. From the above, it seems to be some kind of non-linear, log taper, which is normal for volume controls, but what is the taper? How did it change, if it did, was there a different design philosophy behind each system. Or did it depend on what the taper was of whatever component was used for the volume control?
Hi Jeff,
This is basically what I'm trying to reverse-engineer... Of course, I know the behaviour of the current products, but I'm trying to find out how it intersects / overlaps with the older products. THis is happening in conjunction with some conversations with some colleagues who worked on the older products to find out the reasons behind the different scales.
Cheers-geoff
