TAGS
Answered (Verified) This post has 1 verified answer | 8 Replies | 3 Followers
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Ƨcɑɽɑɱɑnɡɑ posted on Sun, Feb 5 2012 5:17 PM
Not that I use them... but where can they be found now?
I just tested some.
  • One B&o bottle opener
  • One fancy gun
Keith Saunders
Hampshire, United Kingdom
When TAGS are used they are shown on the right in the tag list and the number of posts with the tag are shown in brackets
Regards Keith....
Keith Saunders
Regards Keith....
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
They are there now!
  • One fancy gun
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Now,
edit (as in post) and edit tags only show in "questions" NOT "discussions"
Will write down and reply to the feedback blog
  • One fancy gun
Rich
Orlando, Florida, USA
Rich replied on Sun, Feb 5 2012 7:46 PM
Keith Saunders:
So when Jeff clicks on "Suggest as Answer," it turns into "Verified by burantek?"  Cool.  That's two "Me likey's" in five minutes.
Beobuddy
Utrecht, The Netherlands
Bit confusing that the name isn't near the avatar.
The Member online message is bigger than the poster's name.
Just a matter of get used to I think.
Beobuddy
Just solved I see Big Smile
Keith Saunders
Beobuddy:
Is that better now ?
Regards Keith....
Beobuddy
Yes, it's better! Maybe a slightly bigger font? Or does that give any problems with longer names?
Page 1 of 1 (9 items) | RSS
