Beolink Activ as audio master ?
Not Answered This post has 0 verified answers | 4 Replies | 0 Followers
Silou
Switzerland
Silou posted on Tue, Sep 3 2019 12:45 PM
is it possible using a Beolink Activ as audio master ?
Audio input on BL Activ with IR eye - ML cable to an another BL Activ / or a BL3500?
BeoLignage
Sweden
Hi Silou
unfortunately not, the audio input on the BL Active is the so called PC input and can only be selected locally.
see the manual page 7 on:
https://www.bang-olufsen.com/~/mediaV3/files/user-guides/BeoLinkActive/beolink-active_settingupguide_english.pdf
Silou
Switzerland
Silou replied on Wed, Sep 4 2019 5:17 PM
Thanks BeoLignage,
I missed; PC is locally only !!
What's about  BL Converter 1611 ? (An master seems to be necessary... )
My goal is to inject an external source into ML with the easiest/smallest "ML-managerdevice" .
BeoMatthew
Nope. A BeoSound product with ML would have to be present. Link kits cannot communicate with one another independently.
RaMaBo
near Munich
ONLINE
the Beolink Converter 1611 can be used as a Masterlink Master for a Masterlink Network.
The audio has to be 'pushed' in via the DIN connector A.AUXLink. The signal will be sent on the masterlink bus and can be used with various Beolink Slave devices (BeoLab2000, BeoLab3500).
The sound can be remote controlled with a B&O remote ( Vol+/-, Mute, Standby, Balance ...) to switch on the Mastelink Slave any audio command can be used like RADIO, CD,TAPE,...
This definately works fine.
Ralph-Marcus
Page 1 of 1 (5 items) | RSS
