Using 2 Beolab11 with BeoLab 3
Not Answered This post has 0 verified answers | 4 Replies | 1 Follower
Surt
Surt posted on Sun, Aug 18 2019 12:51 PM
Is it possible to use 2 BeoLab 11’s with a Moment and BeoLab 3 setup.  Can this be done with standard wiring.  If possible would the benefits be worth the cost.  The use is for music not TV.  Thanks
leosgonewild
Helsinki, Finland
Overkill
henrik
Sweden
henrik replied on Sun, Aug 18 2019 8:29 PM
leosgonewild:
Overkill
I agree. Also, I don't find the 11 and 3s being a very good match. I use my BL3s with one BL11, the 3s connected to the output of the 11 and the 11 to a Core, and to me it sounds like the lowpass filtering in the 11 removes a bit too much for the 3s – it sounds like there is a quieter gap between the lower and the mid bass. I guess thing would be better if a Beovision was used, but based on my experiences I would not recommend the BL3+11 combination for a system without manual control of crossover frequency etc.
...but that's just my personal opinion. others might have better experiences of this combination.
Manbearpig
Silver Member
I run 3s and 11 through a surround processor, slightly elevating bass on the 11. Very satisfied with that combination.
Kai
x16szr
x16szr replied on Mon, Aug 19 2019 5:06 PM
I am using a S8 and in my opinion an BL11 is a quiet good Subwoofer,
but at a little bit higher music volume levels it is at its end.
Because of his relativly small woofers of 10 or 11 cm.
I was very happy with it, but with S8 it is very very better... i think. Smile
Greets, Stefan
Beosystem 4 , Beoremote One, Samsung LED 65 Zoll, ATV4 PUC, BL 8000 Frontspeaker, Center BL 7.1, BeoPlay S8 black Rear Wandhalterung, Beosound Essence MK2 mit IR an Beolink passiv an Bose 161 weiß, Beomaster 3000 mit Beocord 3000 an BeoVox CX50 weiß, BeoCom 1401 mit IR Control, BeoCom 2000 weiß, Beoplay M5, Ex-Beosound Ouverture RDS, Ex-BV 10-40 MK3 mit Beo4 DTV an Dreambox 500V2, Ex - Beoplay V1-40 weiß , Ex-BV 8-26 mit Beo4 DTV an Technisat Digit S2e PUC, ex BeoSound 3, Ex-Beolit 12 Darkgrey, ex B&O A8 Earphones
Page 1 of 1 (5 items) | RSS
