Beoplay Remote for macOS (PoC)
Not Answered This post has 0 verified answers | 41 Replies | 6 Followers
tlk
Denmark
tlk posted on Fri, Aug 9 2019 12:15 PM
Hi there,
I thought it would be nice to be able to remote control my Beoplay M5 speakers from macOS, so I created a little proof-of-concept tool to be able to do just that. The code is available at https://github.com/tlk/beoplay-macos-remote-gui and you need to build the software yourself with the latest XCode beta if you want to try it out.
With this little tool it is no longer necessary to reach out for your phone (and open the B&O app) to adjust the spotify volume or stop/start a tuneIn radio station - just scroll the little volume slider in the mac status menu or use the keyboard shortcuts.
I previously asked for suggestions on how to remote control the Beoplay volume over at Spotify, and it seems like other people have been looking for something similar.
Would it by any chance be possible for B&O to consider making a functionally similar piece of software available through the MacOS Appstore?
Best regards,
  Thomas
Screenshot:
Carolpa
kuyttendaele:
Downloaded in on my iMac.
It does find my BeoVision 14. But changing the volume does not work. So I guess it only works for the BeoPlay range of devices.
Karel.
Beosound Moment: volume, next, back, pause works, sources (including join) not (grayed out).
Beovision 11: no response
Beovision Horizon: no response
Beolink NL/ML converter: does not work (at least in my setup)
Beosound Essence mkII: volume, next, back, pause, sources works
Beosound Shape ( & Beosound Core): volume, next, back, pause, sources works
Beoplay A6: volume, next, back, pause, sources works
Beoplay M3: volume, next, back, pause, sources works
Beosound 35: volume, next, back, pause, sources works
Beovision Harmony: volume, next, back, pause, sources works
Edit: ones a device is chosen with greyed out sources (such as the Moment), the sources for ALL devices are grayed out and stay so. The app must be restarted to get sources again.
mbolo01
Louannec - France
Carolpa:
If you didn't notice it already, controlling a Moment with the app triggers high CPU usage on the Mac and the app must closed to recover. At least this is what happens for me with the latest iteration of the code (not the one in the current DMG)
TWG
TWG replied on Tue, Sep 22 2020 7:23 AM
Very nice tool. Thanks for that Thomas!
Can you program this for PCs, too?
tlk
Denmark
tlk replied on Wed, Sep 23 2020 3:29 PM
Carolpa and mbolo01 thanks for the feedback! I have checked in a small update that may prevent the bug triggered by connecting to the Moment. Tracking the issue in github #26
tlk
Denmark
tlk replied on Wed, Sep 23 2020 3:37 PM
TWG, you are welcome - happy to receive feedback from you. I believe I could make a similar tool for Windows and other platforms but I am afraid it is unlikely to happen pro bono.
best regards,
  Thomas
laseralex
tlk:
How much would it cost?  I'd be very willing to chip in $250 if others are interested and willing to contribute.
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II
Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2
Integrated:  1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6
Control:  16x* Essence Remote  • 1x Beoremote Halo
* Yes, really! 🤦‍♂️
mbolo01
Louannec - France
Carolpa:
FYI: The latest version of the code can now properly control the BS Moment, including sources and TuneIn stations ! Better than the Halo can do :-)
Carolpa
Carolpa replied on Fri, Sep 25 2020 12:39 PM
mbolo01:
Carolpa:
I noticed yesterday but didn't find the time to Thumbs Up, in my setup only the BV11 and the BLC can't be controlled (but the shared sources of a ML product with a NL product, f.e. a Essence mkII do work)
beojeff
USA
I'm curious what the obstacle is that prevents control of BeoVisions/BeoSystem 4 and Nl/ML Converters -- since the Halo cannot control these either.
Carolpa
"Program Killer"; just setup my new Mac Mini with Apple's M1 processor.
Now the B&o app and the Beoliving app can be run on the Mac itself Big Smile
tlk
Denmark
tlk replied on Mon, Dec 7 2020 5:39 PM
Excellent! Does it support hotkeys?
Carolpa
tlk:
until now I didn't find a way
Page 3 of 3 (42 items) < Previous 1 2 3 | RSS
