mbolo01: beojeff: I have a Moment integrated with a BeoVision 10 via an NL/ML Converter and it does not appear as a choice when expanding music. Isn’t it related to the NL/ML issue introduced by the latest Moment’s software?
I had my Moment's software rolled back to the stable version.
beojeff: mbolo01: Hiort:When I had a Moment (integrated with BV11) I could expand music to that device by tapping “+” in the Multiroom view.Correct, the Moment can be added to a multiroom experience the way described by Hiort, like any other NL product. I have a Moment integrated with a BeoVision 10 via an NL/ML Converter and it does not appear as a choice when expanding music.
Does the Moment have its own speakers?
Carolpa:Is the BLC set as A Slave or A Master? Does the Moment have its own speakers?
When using Airplay for playback and parallel using the B&O App.
You see the played Track Name and Artist Name at the Control View (?) but in the Listening View (?) you only see the Track Name (see attached screenshot). It would be great to see the Artist Name, too!
Another question, when I use Chromecast (with Deezer App) I get the cover art displayed in the Listening View of the B&O app, when I use airplay (with Deezer App) there is NO cover art. Why?When I stream Deezer App via Airplay to my Apple TV the cover art is shown. So the information should be included in the airplay music stream. Why is the B&O app not able to display the cover art when using Airplay?
Is this the user interface design quality you expect from a high price design brand?On the music main page (Apple iPad)
You see 9 different genre. If you want to see all 20 genre you have to klick on „show all“. Scrolling does not help, you only see another 6 (total of 15 not all 20) but not all (why?).
Now you see 2 different genre (before you saw 9) at the same time and you scroll and scroll and scroll and scroll and scroll and scroll and ... to see the missing 11 (and only 2 genre at the same time).
I am not surprised, that the B&O App is with high distance the worst rated app compared to competitors in the Apple App Store. And just setting back the rating counter will not help, as long as the user interface quality stays like this.
I hope that some B&O officials are still reading this thread even the new version 2.7 is released and no more feedback is written by Mr.Andersen since then.
I am very disappointed that the bug that courses a freezing app (after 3 to 6 minutes when there is WLAN / LAN connection to B&O products but no Internet connection) is not solved!
Instead „very important“ issues are implemented, like round instead of squared artist pictures and left-justified instead centered captions. WoW that is really the correct priority, wasting time and money for non-sense changes nobody needs. But leaving B&O customers with their problems in the rain!
I am one of the many very disappointed B&O customers.
MrAndersen: @1990: The timer could be a bug, let me look into it.
Another issue with the Integrated Setup:
1. I start playback on my integrated Essence
2. I Join the experience from a second device
3. Playback on my Essence stops because of my timer settings.
4. Now after a few hours, I want to stop playback on my second device. I can't achieve that anywhere.
Selecting the second device is impossible because it is in Multiroom-mode. Selecting the V1 that is integrated with my Essence doesn't deliver any options for changing/stopping what is currently playing. I can stop playback through the manual controls of the second device or the remote that is connected to it, but not via the app. I can only put the entire system in standby on the homepage. If I recall correctly, this didn't happen in previous iterations of the app.
@Seethroughyou: It might have changed IP, remove it and adding it again should resolve it
@alsfeld: I have regsitered your bug and we will take a look. We're not getting cover art from Airplay from the products. For Chromecast it depends on the source
@mm08642: I cannot repro this, but it might be iPad only. We will take a look.
@HH1971: We are not seeing this issue in our tests. I will take another round with QA
@1990: yes, we are aware of this case. No good solution but all standby for now. We will add play pause to the followers in an upcoming release
Regarding the missing album art in the PQ. It is working for the 4 different NAS drives we have in the office. From another customer we got it that he used a Beomaster 5. Is that the case for you as well?
@MrAndersen: did you manage to reproduce product status update failing when app is in the background?
Scenario:
- App is running in foreground, product A and B are seen active- App is moved to bacground- Product A is powered off- App is brought back to foreground- Product A and B are seen active, even after waiting a while
MrAndersen:Regarding the missing album art in the PQ. It is working for the 4 different NAS drives we have in the office. From another customer we got it that he used a Beomaster 5. Is that the case for you as well?
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
MrAndersen: Regarding the missing album art in the PQ. It is working for the 4 different NAS drives we have in the office. From another customer we got it that he used a Beomaster 5. Is that the case for you as well?
Album art missing in PQ for me too, tested with Twonky and Minimserver against a Core.
Dyssegaard:Just retested the DLNA PQ cover art issue on my M5: The problem is still there. It has worked in previous versions. My NAS is a WD My Cloud Home with a PLEX DLNA server. Best regards - Dyssegaard Family room: Beovision 11-40 / Beosound Core, Beolab 3 (front), Beolab 8000 / R1 (back), Beolab 2 (sub), AppleTV 4K, Chromecast. Bedroom: Beoplay M5. Home office: Beolit 12. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Library: A6, Beocom 6000 Bedroom: M5 Office: Beocom 2 Travel: Beoplay E8 2.0, Beoplay P2
Same here - albumart shows up when browsing, but not in the queue!
In the main window however, I have the coverpic of the now playing song.
Used to work previously.
Older Synology NAS - preinstalled server there.
Version coming out tonight fixes Deezer picks. The PQ album art has been found and the fix is due tomorrow. Looking at the rest
Find a way to lower the volume level of TuneIn to that of other sources!
MrAndersen:@mm08642: I cannot repro this, but it might be iPad only. We will take a look.
Thank you very much for looking into the bug / error.
Perhaps the following will help you, to identify the reason for the bug.
As long as I only use the Beosound Moment, the B&O App works fine within my LAN (without internet connection - I just pulled the DSL connection of my Fritz!box Router) - I tried it for 45 minutes. BUT as soon as I turn on my Beosound Shape (switching on the power) it works fine for another 5 to 10 minutes. I even can start playing music on the Shape from my local NAS via B&O App. But after 5 to 10 minutes, the B&O App freezes. The music goes on playing, but because the B&O App is not anymore working I can not control the Beosound Shape anymore.
I hope you can solve the problem.
MrAndersen:The PQ album art has been found and the fix is due tomorrow. Looking at the rest
It seems that PQ is emptied when selecting a new album now which is great and as I would expect. Thankyou!
However, I think I've noticed a new bug. It seems that the albums are entered into the PQ twice and in an odd order. For example, if I add an album with 4 tracks my PQ will look as follows -
Track-1
Track-2
Track-3
Track-4
Also the device will start playing from the second Track-1 and continue playing from there.
I have tried this with multiple albums on Deezer and on all my B&O devices. It seems to always happen with one time the album being added to the PQ three times.
Dion.
BeoVision Avant55 Mk1; Theatre with BeoSystem4; BeoSound2; BeoPlayA9 Mk4; BeoPlayA6; BeoPlayM5; BeoPlayE6; BeoPlayH3 ANC
..and it all started 15 years ago with a pair of B&O A8 Earphones...
Hi Dion
That sounds odd. Just tried it several times and it doesn't happen to me.
Just to clarify
Click an album
Click the play icon
Go to the PQ and the tracks are duplicated?
Is the queue empty when you do it?
Br
Thomas
Dion:It seems to always happen with one time the album being added to the PQ three times.
Dyssegaard:It is not possible to change the product name on my M5:
mbolo01:Same here, as well as for the Core (M3 and BS1 are ok, A6 not tried yet) BS Moment, BS Core, BS Ouverture, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
Thank you very much for looking into this issue. Yes, it is worst on the iPad in landscape mode. The described issue you experience on small displays like on the iPhone, too. But there it is not so extrem.
B&O really should invest much more time / money in the user interface and technical features that are state of the art in other apps. The experience the B&O app is offering would be OK for a low cost Chinese loudspeaker manufacturer. For a design company placing themselves in the high price segment, the offered B&O app is still far away from my expectation I have on a product in this price segment.
And when you look at the ratings in the Apple App Store, I am not the only one who is strongly disappointed. And just setting back the rating counter with every release will unfortunately not help to improve the app at all
MrAndersen: Hi Dion That sounds odd. Just tried it several times and it doesn't happen to me. Just to clarify Click an album Click the play icon Go to the PQ and the tracks are duplicated? Is the queue empty when you do it? Br Thomas
Hi MrAnderson,
Sorry for the delay in responding, I have been travelling and away from my B&O setup at home.
What you have clarified is correct, that's exactly what happens. I have just tried again with Pink Floyd Animals (5 track album) and it has resulted in the album being placed in the PQ three times with track1 in first and playing from the third entry. I cleared the PQ and it did it again. Screenshot below.
This is the latest beta of the app running on Android.
Let me know if there is any more information I can provide to help find this bug.
Kind regards,
Dion
MrAndersen:@mbolo01: The white artist image is not yet fixed. This is a different issue and we need to put a light gradient on it or detect white and change the control color
mbolo01: Dyssegaard: It is not possible to change the product name on my M5: Same here, as well as for the Core (M3 and BS1 are ok, A6 not tried yet)
Same here on M3, couldn't change name.
They're no fields for change name, or grey in the edit field by BeoTool.
Contact the B&O customer support, they tell, select Product options en then change name. Or remove product from app and start from stretch so you give it a name, both options without succes. They don't know where they talking about....
@ B&O possible to fix this issue??
bs206: both options without succes. They don't know where they talking about....
Have you tried going to the M3 Configuration page, then Network and change the name here?
EDIT: Just checked on my M5, this option is no longer editable in the configuration/network page, looks like a product/software issue, not an app issue.
mbolo01:Have you tried going to the M3 Configuration page, then Network and change the name here? EDIT: Just checked on my M5, this option is no longer editable in the configuration/network page, looks like a product/software issue, not an app issue. BS Moment, BS Core, BS Ouverture, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
I have noticed that, how do you add the product to the Home App? They ask a number...
Dyssegaard:[ I tried to do the same for my M5, and the network configuration page tells you to use the Apple Home app to change the name:
Good catch, I see the message too ... now that you read for me!
bs206: I have noticed that, how do you add the product to the Home App? They ask a number...
Apple Home App, must scan the code below, but than he can't find the product...
Ridiculous that you need the Apple app to change the name of a B&O Product.
bs206:I have noticed that, how do you add the product to the Home App? They ask a number...
....and what if I DON’T want to use the Home app at all?
I don’t use AP2 here - I prefer BeoLink for distribution of Airplayed sources!
@Mr. andersen - please clarify!
Works, find the M3 but can connect to the product
I will try again it later...
Millemissen: ....and what if I DON’T want to use the Home app at all? I don’t use AP2 here - I prefer BeoLink for distribution of Airplayed sources! @Mr. andersen - please clarify! MM
Agree that!!
Hi guys
It is simple and sad. Apple do not allow us to change the name if you have used Apple Home to setup your product. If that is the case we must make it read only or fail certification.
Sorry but my hands are tied in this case
