Lee's S45 speaker
Not Answered This post has 0 verified answers | 17 Replies | 1 Follower
Craig
Yarm, United Kingdom
Craig posted on Thu, Aug 1 2019 8:10 PM
This was delivered in the post today, usual issue.....cone seized solid in the coil.
Craig
Otherwise its in very good shape, coil measures up at 3.4 ohms, cone and rubber both in good condition, one can see that the issue is the magnet has shifted on the frame...been knocked I expect....doesn't show well in the picture but it is off to one side.
Craig
Clamped it in the vice and popped it apart, for me the most scary part of the exercise, once its separated out each part can be rubbed down and the old adhesive removed.
Craig
The magnet and its mating face on the frame cleaned up first prior to allying epoxy, need to be careful to put the magnet back in the same polarity.
Craig
This doesn't need to be dead centre on the frame, but the closer it is the better.....
Craig
The rear plate and core need to be cleaned up too, old adhesive removed....
Craig
And then they need epoxying together.....they need to be placed on a completely flat surface or the core floats around!
lee
chester uk
lee replied on Fri, Aug 2 2019 8:51 PM
Ooooh... glad someone knowledgeable is doing this :-D
thanks for updates craig
And for quick progress!
frugal audiophile
Craig
Dust cap lifted off with the assistance of the girlfriends hairdryer...….
Craig
When the epoxy has cured the base plate is held in a vice and the frame, magnet and coil are carefully lowered onto the upright core. then the "alignment jig" is fitted, a saucepan is useful to rest everything on
Craig
Adjusting the screws around the lower half of the jig secures it to the magnet, then looking through the dustcap one can adjust the upper row of screws to centre the core in the coil.....
Craig
This takes very little time and once happy epoxy is applied before opening a bottle of wine...….
lee
chester uk
lee replied on Sat, Aug 3 2019 11:16 AM
great work!
Any recommendation on wine for this repair :-)
frugal audiophile
lee
chester uk
lee replied on Sat, Aug 3 2019 11:17 AM
great work!
frugal audiophile
lee
chester uk
lee replied on Sat, Aug 3 2019 11:20 AM
Will be on the look for some stands for these I think... might have to make some since they are reasonably rare I think...
frugal audiophile
Page 1 of 2 (18 items) 1 2 Next > | RSS
