Simple powerlink start circuit
Not Answered This post has 0 verified answers | 7 Replies | 1 Follower
DMacri
United States
DMacri posted on Sat, Jul 20 2019 1:24 AM
I am sorry to say, I've spent much more time in management than I ever did in electronic design, the degree I earned at my university. So, I'm looking for a very simple circuit I can use to turn on the tube amplifier I designed using a powerlink signal. I am doing this to help tie my two loves - tubes and B&O together. This way I can use a Beomaster to drive a nice pair of passive speakers using my tube amp. Anyone have a simple circuit I can use to turn on a relay? Otherwise, I'll break out my design manuals and have a go.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, and ambio
trackbeo
Silver Member
In my files area are pics of what I built.  It's unsafe junk, but drove a Carver M400 cube from a BeoCenter 2500 for years.  [Edit: deleted]
solderon29
U.K.West Midlands
B&O used to make an auxillary box to do this,although it wasn't designed for Powerlink,and needed 12v to trigger it,whereas the Powerlink trigger is 5v.
I think Steve at Sound's Heavenly does something for this purpose though,as often Beoworlder's want to drive an auxillary power amp.
Send him a message explaining what you  need?
Nick
Peter Pan
ONLINE
Hi DMacri
Guy
Buckinghamshire
Guy replied on Sat, Jul 20 2019 5:49 PM
solderon29:
This was the box - they still come up on eBay occasionally: https://www.beoworld.org/prod_details.asp?pid=1246
.. and mine worked fine with a Powerlink 5v trigger, supplied by the RJ45 socket of a Playmaker to turn on a BM900 as its amp!
A couple of alternatives:
- This trigger circuit design is posted in the Beotech section of this site: https://www.beoworld.org/beotech/circuit.htm
- You could possibly use one of these with the Beomaster in the 'master' socket and the valve amp connected to one of the 'slaves': https://www.amazon.co.uk/CrazyGadget%C3%82-Automatic-Energy-Protected-Extension/dp/B00YZ50CE0/ref=pd_sbs_23_1/261-0402616-5327328?_encoding=UTF8&pd_rd_i=B00YZ50CE0&pd_rd_r=22113fae-cd85-49a0-94e7-01dba465ff54&pd_rd_w=7QfOB&pd_rd_wg=VZ1go&pf_rd_p=18edf98b-139a-41ee-bb40-d725dd59d1d3&pf_rd_r=388RY3ZS5GQ2B7Q8T3GS&psc=1&refRID=388RY3ZS5GQ2B7Q8T3GS
DMacri
United States
DMacri replied on Sun, Jul 21 2019 1:38 AM
Guy:
This is exactly what I needed. I can use the tube heater circuit for the power source. Thanks.
Dom
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Hi DMacri,
It sounds like you have a few options there.  Please let me know if you need something to be built and I can sort this out for you.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (8 items) | RSS
