Beolab 50 randomly looses contact with slave speaker
Not Answered This post has 0 verified answers | 17 Replies | 0 Followers
Sweden
Martin posted on Tue, Jul 16 2019 8:06 AM
I have had my BL 50 in two month now. During this time the slave speaker has lost its contact 4-5 times randomly. I have changed cat6 cable between the speakers to a Cat7 but no change.
IS this something software related? Does anyone of you WHO has BL90 or 50 experience this problem randomly from time to time?
Best Regards
Martin Ström
Sweden
Beovision Eclipse 65 with floorstand (from STB Brackets), New! Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K. AURALIC Aries G1 (new)
Razlaw
ONLINE
Razlaw replied on Tue, Jul 16 2019 12:30 PM
I have only had my 50s for five days. Have not had any problems.
Beolab 50s Beolab 9s Beolab 12-3s Beolab 1s Beolab 6000s 2 pairs Beolab 4000s Beovision 7-55 Beovision 10-40 Beoplay V1 32 inch Beovision Avant 32 inch Beosound 1 (CD player) Beosound 3000 Beosound 5 Core Essence MKII Beoplay M5
Mikipidia
Yep, Henrik and I both have had that happen and yes seems to be software related
New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beosound 9000 mk3, Beosound 1 Bronze edition, Beoplay M3, Beoplay A1.
Mikipedia on YouTube (finally Stick out tongue )
https://www.youtube.com/c/Mikipedia
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Sweden
Martin replied on Tue, Jul 16 2019 1:22 PM
great thanks for confirmation. No need to believe that something is wrong with just my speakers:-).
Except for that problem mine Bl50 works very good with the Eclipse.
BEOVOX141
Denmark, West
ONLINE
Silver Member
Mikipidia:
You know these speakers,- would it be possible to run two masters in stand alone configuration? One left and one right?
Mikipidia
Could you? Yes. Should you? No!!
It would take two cat 7, for l/r channels to both masters, cables and they wouldn’t sinc and you’d loose room comp. It wouldn’t be a speaker pair but seen as two sets of separate sets. So while you can for a single front l/r setup you can end up in a world of hurst and confusionStick out tongue
You can have two master connected as sets(with the slaves so to say) but that would be for a surround setup where one master is front (plus slave) and one is in the back/rear(plus slave). That would work. In both situations you’ll have two (sets) of 50’s in the app too and you’ll have to configure them independantly.
BEOVOX141
Denmark, West
ONLINE
Silver Member
Mikipidia:
They wouldn't have to sync since the signals arrive at exactly the same time and the processing time is the same!
And if ONE single BL50 can do room compensation the other one can as well! (this is the part i dont know ?)
Mikipidia
Do you mean wisa? in that case no.
while wired, my understanding is that they need to work as a pair and the master needs to know what the slave is doing and vice versa. But just give it a try and let us know? I would love to know what happens. I doubt it'll work well if at all, but i guess it could function sort of, but I may be wrong.
I was told to never have two masters on the same plain, as in even if you have 4x bl50's to not have both masters front or rear, but one front and one rear.
BEOVOX141
Denmark, West
ONLINE
Silver Member
Mikipidia:
No regular wired,- can you run just the Master?
Forget about the slave for a while,- will the system allow you to setup just the master?
Sweden
Martin replied on Sun, Jul 21 2019 9:34 AM
Hi Mikipedia,
how often Does it happen for you (loosing contact with slave speaker)?
For me it has happened 6 times in Two month! I dont think that is okey.
Best Regards
Mikipidia
Sorry didn’t have acces for a week. Yeah i had more than that i reccon, but i stopped counting honestly. I wouldn’t say its uncommon but not great either
BeoPer
Hi Martin, you got any solution to the issue? I had a new pair now for two weeks and I loose the slave irregularly. I have CAT7 and no wireless. The systems goes silent and the slave shuts down and the Master stays on with no sound. I have to remove power to get them back.
Sweden
Hi Beoper,
There is NO solution yet. My case is a couple of levels up at Bang&Olufsen at Manager level. I Can not accept a product for about SEK 300.000 that not work perfect. The answer right Now from BO is that they are aware of the problem and that it is a software error. This means that maybe they find a fix or maybe they dont. I am considering getting the Money back and hand over the speakers to my dealer. I just wait now for the final answer from BO managers.
I have got one new pair à couple of month ago and they where a little bit better but still the same problem. No one should buy these speakers as they are now.
If you want to know more about This issue please email me at martin.strom@telia.com
Best regards
BeoPer
Thanks for your reply. I'll have to see where this goes...
Esax
Esax replied on Sat, Dec 7 2019 6:18 PM
Why are they replacing the speakers if it is a software problem? And why are there a differens between speakers with the same software?
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Page 1 of 2 (18 items) 1 2 Next > | RSS
