Beosound Moment in 2019
This post has 73 Replies | 1 Follower
mbolo01
Annecy - France
Posts 1,223
mbolo01 replied on Sat, Jul 27 2019 1:42 PM
steve1977:
Have you ever tried to use Minimserver with the Moment and configure alrtists to be served as albumartist? Minimserver allows to do so via a special setting: Artist.displayFormat={$albumartist}
No, and I will not for the reason I explained in a previous post, i.e. the lack of Photo support, but I guess it could be an option to circumvent the "feat." appearance in track artists and rationalize on album artists without loosing the tag on the track itself.
BS Moment, BS Core, BS Ouverture, BG 4002, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
steve1977
Posts 746
mbolo01:
I am very close to pulling the trigger on a Moment. Have some hopes that I can fix my artist list with the logic above.
You mention the lack of photo support. This would not be an issue for me as long as all coverart is embedded in the files, right?
mbolo01
Annecy - France
Posts 1,223
mbolo01 replied on Tue, Aug 6 2019 7:57 AM
steve1977:
Correct, Moment leverages what DLNA exposes which is what is embedded in the file initially.
DLNA server Photo support, on top of Music, is the way to self-manage artists tiles.
steve1977
Posts 746
mbolo01:
DLNA server Photo support, on top of Music, is the way to self-manage artists tiles. BS Moment, BS Core, BS Ouverture, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
Oh... Got it. This is about the artist tile. Would indeed be great to self-manage this. about if that’s what minimserver cannot support, i’ll be fine with grace or (hopefully).
steve1977
Posts 746
steve1977 replied on Sat, Aug 17 2019 7:32 AM
So, I pulled the trigger and will be a proud owner of a Moment. Will report next week how the setup goes. Fingers crossed :-)
A few more questions when setting things up:
I don't plan to connect any Beolabs to the PL of the Moment. I am planning to link the Moment permanently with an NL device (likely my A9). Not with a PL cable, but just configured through the B&O app. Will this allow me to access my Moment DLNA indexed files directly from the A9? Will the "join" function on the Moment still work and allow me to join the A9 into other playing NL devices?
Could I also link the Moment to an ML/NL converter (without cable, but configured through the APP)?
Barry Santini:
Use Bliss Music Tagger and all will be fine
My collection has perfect tags using Picard. I have been reading about Bliss and it seems different from a tagger like Picard? What does it do and will it be useful in combination with the Moment?
AnalogPlanet
Vienna, Austria
Posts 556
I am really interested to „copy“ the procedure how will you establish a permanent NL link between Moment and A9 - in a way that when you press play on Moment the A9 starts to play as if it would be a WISA speaker. I tried to do it myself (have both) but never managed to. Keep us posted and enjoy your Moment! ;)
steve1977
Posts 746
steve1977 replied on Sat, Aug 24 2019 4:37 AM
mbolo01:
I am looking now at my Momment. Nice device and looking forward to get it working eventually ;-)
Have started the setup and seems things are running fine. A few questions:
1) If I were to permanently link my Moment to a NL device (i.e., music playing directly to the NL device rather than PL/Wisa connected speakers), where were I set this up? Is this the MLGW option in setup?
2) I am surprised that the way to get into settings is to take off the back cover. Is this the only way? Seems a bit odd...
3) The Moment is harvesting my DLNA collection from the DLNA server now. Given large library, this will take a few days. Is there a way to see an intermediary result? I could of course setup a second server with smaller library, but wondering whether there is another way to see a status / intermediary result what is being displayed on the Moment based on partial harvesting.
Thanks again for all the help on this forum!
mbolo01
Annecy - France
Posts 1,223
mbolo01 replied on Sat, Aug 24 2019 4:13 PM
You have to do it on the NL device holding the speakers and link it to the Moment. The Moment itself does not have this option. I linked my Core to the Moment so I can play Moment sources from the Core and also direct the Moment sound output to the Core via NL.
Yes this is the only way. The only thing you can do from the App (and only from the App) is the timer settings.
By removing the Moment’s lid you can also check the harvest progression or by using a browser to go to the Moment’s status pages (I can give some details if needed)
steve1977
Posts 746
steve1977 replied on Sat, Aug 24 2019 5:34 PM
mbolo01:
Got it. Now I understand what you are doing. But that's not a real direct link, right? It allows the Core to select audio from the Moment. But it does not auto-join if you play something on the Moment.
steve1977
Posts 746
steve1977 replied on Fri, Aug 30 2019 7:03 AM
Thanks again for all your help.
I have tried MiniM server with the Moment and - much to my surprise - it is all working really well. It's quite close to perfect.
It seems that I in fact only have one real issue. How do I need to set the composer setting that it doesn't get in the way?
Also, I currently don't have any artist art, but it instead shows a random album art. I remember you mentioned that this is a limitation of MiniM server, but it should scrao from Gracenotes, which doesn't seem to happen.
FYI I am not using expert mode (yet). Given almost all seems to work, this may not be needed. What benefit would I anticipate?
mbolo01
Annecy - France
Posts 1,223
mbolo01 replied on Fri, Aug 30 2019 12:36 PM
Q: It seems that I in fact only have one real issue. How do I need to set the composer setting that it doesn't get in the way?
A: can you elaborate? I don’t understand
Q: Also, I currently don't have any artist art, but it instead shows a random album art. I remember you mentioned that this is a limitation of MiniM server, but it should scrao from Gracenotes, which doesn't seem to happen.
A: Artist’s image should be fetched from Gracenote if name matches. If not you may see either a random album cover or a grey tile.
Q: FYI I am not using expert mode (yet). Given almost all seems to work, this may not be needed. What benefit would I anticipate?
A: The Moment rescan the library when it detects a DLNA content change. If your DLNA exposes playlist with last played songs, then the DLNA content has changed as the last played playlist has changed. When you have a large library, Moment is unusable as it keeps scanning and reorganizing its library while playing songs. Expert mode enables you to manually trigger a rescan. Expert mode enable you to self manage your artist image by placing images in a specific directory of the DLNA photo server. As Minimserver does not have the photo feature, you cannot leverage it for that (answer to part of your the second question)
Note: I have answered to your previous post but it seems blocked.
steve1977
Posts 746
steve1977 replied on Sat, Aug 31 2019 1:38 AM
mbolo01:
I solved it and now all artists show 100% properly. I removed the extra command from minimserver to display composers as artists. This made my classical albums a bit less perfect (they now show by albumartist), but thta's fine and maybe even better this way. And was needed to prevent some regular albums (like UB40 above) to show oddly.
Overall, I now have all albumartists showing correctly and even the albums seem to show in the right order by release date. I assume this is thanks to minimserver and may not work on other dlna servers
mbolo01:
I believe it shows the latest album cover. And if this album cover does not exist, it shows grey. It seems to not fetch anything from gracenotes for me. Does this require some setting to enable or expert mode?
mbolo01:
I'll be patient ;-)
Thanks for your help. I wouldn't have bought the Moment without your guidance on this forum. And I am very happy with it!
steve1977
Posts 746
steve1977 replied on Sat, Aug 31 2019 4:01 AM
Been playing a bit more around to “link/tie” the moment to an NL speaker.
I can link the moment, but this will still require me to select the respective source.
Also, i tried to join with the “+” in the app, which works very well. However, after pausing the music from the moment and waiting some time, it unjoins and i need to hit “+” again, which is an inconvenience. i assume that’s caused by the no devices going on stand by and forgetting they were part of a nl group.
Assume there is no other way to make this work? not end of the work, but a pity that i cannot more permanently tie the moment to an NL devices. Creates interest though to buy a wisa speaker. Unfortunately, BL5 aren’t wisa and none of the more recent BLs with wisa fit my taste (or budget). Waiting for something new to come...
mbolo01
Annecy - France
Posts 1,223
mbolo01 replied on Sat, Aug 31 2019 8:55 AM
Steve: Overall, I now have all albumartists showing correctly and even the albums seem to show in the right order by release date. I assume this is thanks to minimserver and may not work on other dlna servers
Mbolo: I’ll give a try with Minimserver to confirm the sorting side. In the past I managed to have Twonky fixing some bugs in the way they were exposing the release date and I confirmed the fix through Glider, but the Moment was not processing correctly and is still not
Steve: I believe it shows the latest album cover. And if this album cover does not exist, it shows grey. It seems to not fetch anything from gracenotes for me. Does this require some setting to enable or expert mode?
Mbolo: there is no setting for Gracenote. Isn’t UB40 artist shown? It is on mine. I think they leverage the track artist and not the album artist to group songs behind an artist tile. But I guess that for UB40 you have this value in both song and album artist field.
Steve: Thanks for your help. I wouldn't have bought the Moment without your guidance on this forum. And I am very happy with it!
Mbolo: You are welcome.
mbolo01
Annecy - France
Posts 1,223
mbolo01 replied on Sat, Aug 31 2019 9:02 AM
Steve: I can link the moment, but this will still require me to select the respective source.
Mbolo: the way I operate is the following:
Core linked to the Moment
(1) I can start any source on the Moment directly (Jukebox) and it will wake up the Core and Wisa speakers.
Volume is controlled by the Moment
(2) I can also start a Moment source from the Core (via the app or the attached Essence remote), volume is controlled by the Core
Have you tried option (1)?
steve1977
Posts 746
steve1977 replied on Sat, Aug 31 2019 9:53 AM
mbolo01:
Let me do some tests whether it’s indeed the album order. Maybe just by coincidence the few i checked.
One thing to watch is that i’ve tagged my files to the original release date rather than the release date. You know what i mean?
Glider no longer works for me. No idea why, but it gets stuck at initial scan and then doesn’t resume. you’ve experienced the same? * off topic *
mbolo01:
No, it instead shows a ub40 album. That’s the same for all my artists besides a few grey ones (which are the ones that have a grey album cover art).
The grouping works very well as i’ve asked minimserver to send the albumartist as artist. Maybe this somehow ruined the gracenotes feature? it makes grouping behind tiles perfect though.
mbolo01:
BS Moment, BS Core, BS Ouverture, BS1, BL18, BL19, BL8000 + RCV1, A1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
BS Moment, BS Core, BS1 (old), BS1 (new), BLC (2x), BL8000 (2x), BL3, BL2, BL11, BC2, A1, A9, H2, H4, H6, M3, BV5, BV7
steve1977
Posts 746
steve1977 replied on Sat, Aug 31 2019 9:55 AM
(2) works, but is not what i prefer to do.
How do you do the “link” for your first use case? That’s what i’m trying to do.
mbolo01
Annecy - France
Posts 1,223
mbolo01 replied on Sat, Aug 31 2019 2:49 PM
steve1977:
You cannot link from the Moment side, the option does not exist. I « accidentally » played something from the Moment and found that it directed the music flow to the Core. Try it, it could work with your NL device linked to the Moment, otherwise it means that it is peculiar to the Core.
mbolo01
Annecy - France
Posts 1,223
mbolo01 replied on Sun, Sep 1 2019 9:18 PM
steve1977:
I’m back home and while checking I could see that my Moment is no longer showing artist’s images from Gracenote but grey tiles with exclamation mark. I’ll raise a ticket with B&O support, hopefully they have not dropped the Gracenote contract ....
Alsfeld
Posts 109
Alsfeld replied on Fri, Sep 6 2019 12:02 PM
mbolo01:
To access the Moment « database » content, use the following URL with any browser:
http://1 xxx.xxx.xxx.xxx /BeoContent/music/dlnaProfile/track/?offset= n &count= m
Where "xxx.xxx.xxx.xxx" is the IP address of your SoundHeart , "n" is the starting point from the first track in your database (0 is the default), "m" is the number of track per page (default is 50)
Dear mbolo01, tried your URL suggestion, but unfortunately I get only a error message:
when I enter "http://192.168.2.20/BeoContent/music/dlnaProfile/track/?offset=0&count=50"
I get the message "The requested url 'http://192.168.2.20/BeoContent/music/dlnaProfile/track/?offset=0&count=50' was not found."
What is wrong in my URL?
mbolo01
Annecy - France
Posts 1,223
mbolo01 replied on Fri, Sep 6 2019 12:44 PM
Alsfeld:
My fault sorry Unsure
You need to specify the port 8080 such as
http://xxx.xxx.xxx.xxx:8080/BeoContent/music/dlnaProfile/track/
mbolo01
Annecy - France
Posts 1,223
mbolo01 replied on Wed, Sep 11 2019 11:43 AM
FYI: As I was seeing inconsistencies and error messages in my Moment, I decided to perform a factory reset and I can now confirm the following serious issues:
(1) Deezer collection fetch is not only taking into account my preferred artists/albums/tracks but much much more .... e.g I have 145 Deezer favorite artists, Moment fetch 5468 ..... I have 500 favorite albums, Moment fetch 8197 .... very long useless process.
(2) No more Mood nor artist images are collected for DLNA tracks. I suspect a Deezer API issue for the first one, could be linked to issue (1) and  Gracenote failure (API change or subscription fees not payed) for the second one
(3) MoodWheel is consecutively grey .....unusable.
Do you have the same issues?
kimhav
Sweden
Posts 174
kimhav replied on Thu, Sep 12 2019 3:11 PM
Just glanced through this new thread and recognize some of the issues posted here and while B&O pulled the plug on this unit but question if it still would be worth trying to compile a bug list of the most critical issues and see if it's possible to get them to fixed biggest issue? This is of course without know what they have in pipe and whether the could re-use the efforts in any other current or future products. But, as many in similar threads, if the Moment was released as in current state, with some minor additonal tweakes removed from the original release, it would have far better success.
Also, is it worth pushing the Twonky camp for tweakings which would benefit the Moment? Among other the constant updated of the various playlist on the Twonky is something that I would like to be possible to disable which would ease up for the Moment in it's update craziness.
Also, I actually yesterday performed a factory reset and currently only using Deezer and TuneIn as I had problem with some of the TuneIn stations that they stopped playing after a while and often after a week or two the Moment got sluggish and slept in for good. So clearly there is issues on my side with the DLNA and I only have around 21k tracks... I've also used Bliss to clean up the archive including that all of the tracks in compilation albums have set the album artist to Various Artists. It's about 50% of the tracks are compilations with various artists.
mbolo01
Annecy - France
Posts 1,223
mbolo01 replied on Thu, Sep 12 2019 10:04 PM
kimhav:
My concern here is that I acquired a product 4y ago that is progressively dropping the features or services I payed for at that time.
Imagine your premium car progressively loosing its capability to remote lock the doors, its start/stop feature, the automatic light detection, its GPS, etc ...
I would like to be able to use my Moment at least for a decade (and I’m fair considering that my Ouverture is still working) in its latest software state, which while buggy is acceptable, but today it looks like Deezer api calls are failing, Gracenote link is broken, DLNA Moods are not fetched anymore when Deezer is not there, in summary the product does no longer offer the initial services I acquired it for. This is not acceptable at all from a customer point of view.
mbolo01
Annecy - France
Posts 1,223
mbolo01 replied on Thu, Sep 12 2019 10:15 PM
kimhav:
I think Twonky is now dead from a support/development perspective.
I’m proud to have contributed to help them fixing some issues, but version 8.5.1 seems to be the latest iteration and when I asked for the ability to have « last played » playlist optional (to avoid the Moment spending its life refreshing), answer was a big NO and for other improvements I asked, answer was « interesting, we will consider it in a future development » ....
mbolo01
Annecy - France
Posts 1,223
mbolo01 replied on Thu, Sep 12 2019 10:24 PM
kimhav:
I’m interesting to know if (1) the Moment shows artist’s image for DLNA artists, (2) if your MoodWheel (MW) inner ring is operational and (3) if yes, do you have DLNA tracks in your MW
Inner ring?
All the above use to work for me and is no longer working after the factory reset
steve1977
Posts 746
steve1977 replied on Fri, Sep 13 2019 2:21 AM
* double post *
steve1977
Posts 746
This development is indeed quite irritating. While I admittingly bough my Moment after it was already EOL, I didn't anticipate that it will become a (still) expensive brick after just one week...
The issues seem to be that gracenote subscription was not extended and that the software does not reflect the Deezer API change?
Do you know whether I could "localize" the moods by including a mood tag in my tags? It would be quite a retagging exericse with Picard, but not impossible if this would solve the mood wheel issue?
mbolo01
Annecy - France
Posts 1,223
mbolo01 replied on Fri, Sep 13 2019 10:00 AM
steve1977:
This is my interpretation, I'm waiting B&O support for an answer on this front, but here are some facts regarding DLNA tracks Mood and artist images:
The Moment used to display the following while playing a given track ("Monologue: Ike's Rap I"):
{"notification":{"timestamp":"2017-02-21T18:40:40.275874","type":"NOW_PLAYING_STORED_MUSIC","kind":"playing","data":{"name":"Monologue: Ike's Rap I","duration":238,"trackImage":[],"artist":"Isaac Hayes","artistImage":[{"url":"http://192.168.1.70/api/stream/gracenote:image?t=artist&id=WEcxA5TV%2Fm0DsbJMnaN4KBWb%2FmBSKiHcpXo7b66OoMdX%2BAWCTzaTjajtIjXSi7grnQmSDzuO%2FmlmOOozpTd5udciJe7cr%2B0qYklKhhDGLpYn2k9e7hEsT8XilGsaEZUEgL5NjXV8LkquOSa%2FM9ISpsEN4WlbCxCowK2mj%2Bxtq%2FQiy3F1b7%2FfAaE%2BcmiYlYhyBstura%2BYQF9Fh7p6mHyGI853aLZAxzKx66YHssod2t5QnnZ3M3H8GzWk5Tw%2FQvWhlG%2FXJZkU11KS7IBWYk5SAdzERq%2BUcNuF9ohXMEhY9R8t40BehsGveEEQ%2FlOCNlfV%2F22y0of7Qc9ANJlfuP119rWhQ9CdiMX3Fa3a8S96JycorIowJRt6fFRh1wuLC9J%2ByJDf4NUbR3dof7%2BdvHlLOBnMfVv2aVP5AVS2A7PaAiXHKx05yzz%2BzaiOIVFPKJxaA8G2pteUtUJDjOjAY8ueTbI6RYXxQOv3","size":"large","mediatype":"image/jpg"}],"album":"...To Be Continued","albumId":"48482","albumImage":[],"genre":"R&B","moodWheelItem":{"id":"2-42993","ring":"core","mood":{"name":"Dreamy Pulse","graceNote":{"id":42993}}},"originalSource":"DLNA","playQueueItemId":"plid-4121"}}}
As you can see above, artist image and mood used to be fetched from Gracenote.
Playing the same track today produces the following log:
{"notification":{"timestamp":"2019-09-10T16:32:02.803510","type":"NOW_PLAYING_STORED_MUSIC","kind":"playing","data":{"name":"Monologue: Ike's Rap I","duration":238,"trackImage":[],"artist":"Isaac Hayes","artistImage":[],"album":"...To Be Continued","albumId":"31311","albumImage":[],"genre":"R&B","originalSource":"DLNA","playQueueItemId":"plid-166"}}}
As you can see, artistimage is no longer resolved and no more mood exists for this track. In fact none of my 45k tracks has a Mood anymore .... but all have : "moodWheelItem":{"id":"0-0","ring":"core","mood":{"name":"","graceNote":{"id":0}}},"mood":{"name":"","graceNote":{"id":0}} which makes me think that this process is broken, potentially due to a failing API or subscription.
Adding Mood metadata to your track will have no effect as the Moment does not look at this metadata (assuming your DLNA server exposes it) but instead has/had a process to fetch the Mood from Gracenote.
The Moment used to manage a kind of Mood index that I guess the MoodWheel process was leveraging to set the MW inner ring placement of a given track based on the track mood value retrieved from Garecnote.
You can see this index here:
http://xxx.xxx.xxx.xxx:8080/BeoContent/music/moodWheelProfile/moodWheelItem/
Where xxx.xxx.xxx.xxx is the IP address of your SoundHeart
steve1977
Posts 746
steve1977 replied on Sat, Sep 14 2019 1:37 AM
Got it. Hope they'll get back to you soon.
It seems that the Moment indeed turns into an expensive brick without this feature. I hope this is just a matter of API change also for Gracenote rather than the license not being extended. There still was an update some months ago, so it seems there is still some developer assigned to the Moment.
mbolo01
Annecy - France
Posts 1,223
mbolo01 replied on Sat, Sep 14 2019 7:00 AM
steve1977:
I think so too.
Fansastic
The Netherlands
Posts 364
ONLINE
Fansastic replied on Thu, Sep 26 2019 6:40 AM
mbolo01:
Hi Mbolo, I have the same problems with DLNA on Moment. Was not able to solve it myself. I see have way more knowledge regarding the technical side of this. Do you have an answer from B&O yet?
Thanks for your update.
Serge
mbolo01
Annecy - France
Posts 1,223
mbolo01 replied on Thu, Sep 26 2019 6:50 AM
Fansastic:
On Sep 18th i received the following:
« We are writing to you concerning your support request number 73065.
Thank you for your patience. The team is currently aware of this issue that may cause your Deezer playlist content to be missing either partially or entirely as well as your Moodwheel to not work properly.
We are investigating this matter internally and plan on resolving this issue, as of now, we would like to ask you to please perform a factory reset on your BeoSound Moment as we have noticed that this might resolve this issue, click here to see how to do so.
However, should the issue persist, we ask you for your patience while we investigate this. »
Patience ... patience .... and a factory reset will not help trust me.
mbolo01
Annecy - France
Posts 1,223
mbolo01 replied on Mon, Nov 18 2019 9:35 AM
Does anybody has encouraging feedback from B&O about the Gracenote issue? On my side I still receive what they call themselves « canned responses ».
It is now two months since I raised the issue to them.
Page 2 of 2 (74 items) < Previous 1 2 | RSS
