Beolab 50 and Turntables - Is the sound digitised
Not Answered This post has 0 verified answers | 91 Replies | 0 Followers
Epsilon20
Silver Member
Epsilon20 posted on Thu, Jun 27 2019 3:19 PM
Hi Guys, I've been offered a LINN Sondek LP12 at a great price to use with my Beolab 50s  and considering buying it however. The Beolab 50s and more recent speakers  as i understand it is a digital speaker and if i were to connect the turntable to the speakers via the phono in (first through a phono stage) the speaker would digitise the sound which takes away the whole reason of getting a Turnable /analogue source.
Am i correct in thinking that turntables with B&O systems of recent times 17s, 18s, 20,50's & 90s is pointless if you want an analogue sound? I hope not Crying
I've already bought Vinyls and was about to pay for the Linn sondek which is an absolutely beautiful and great sounding turntable.
Beovision Eclipse 55 Brass Edition with Oak covers and Brass Orbital stand
Beolab 50s silver & Oak, Beolab 18 Brass with Smoked Oak, Beolab 18 Rose Gold with Maple Covers, Beolab 19 Black.
DMacri
United States
DMacri replied on Sat, Jun 29 2019 12:17 PM
Jeff:
Jeff
Ok, I have to explain myself. So the BL50 is a system with an ADC front end for the analog inputs, a digital input feed, a DSP for applying signal modifications, a DAC to convert this all back to analog to feed the amplifiers, which in turn drive the speaker elements. I skipped over the electronic crossovers, but you get the point. So adding another external converter of any type is bound to damage the sound. Just feed the Beolab the best signal you can and you should be fine.
Now if you have a component of any type, it has to contend with the quality of the power supply, the signal it receives, and the environment it is in including heat from within in operation and the ambient air temperature. I am simply stating that a component designed for two input signals may respond a little better to having to process just one because the current demand would be lower, and there would be no influence from another signal to contend with - no cross-talk from the alternate signal channel. I could imagine the ADC to have better performance only half loaded. So maybe a tried and true ADC component running half of its capabilities is just fine and the circuit would not benefit from a higher spec chip running at a higher sample rate and/or bit depth.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, and ambio
BEOVOX141
Denmark, West
Silver Member
@ DMacri
DMacri:
120dB is considered threshold of pain for sound.....
Mikipidia
ONLINE
Iam not sure iam following but besides having amps the slave speaker is basically passive so iam not sure how you’d do this.
New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0
Mikipedia on YouTube (finally Stick out tongue )
https://www.youtube.com/c/Mikipedia
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
BEOVOX141
Denmark, West
Silver Member
Mikipidia:
Where did you get that idea from  Confused  Please elaborate
Jeff
USA
Silver Member
Jeff replied on Sat, Jun 29 2019 2:02 PM
I follow the conversation Dom, I just am amazed at the lengths some people go to, not you, to argue about how many digital angels can dance on the head of a pin.
Jeff
DMacri
United States
DMacri replied on Sat, Jun 29 2019 2:07 PM
Epsilon20:
So I guess in the end the answer is "no, it is not pointless". You can route the analog signal from your LINN/preamp combination to the Beolabs, or use an outboard ADC, if you think it may provide superior performance, and route the digital signal to them. Either way, the original analog signal will be digitized, but that doesn't mean the signal will be altered so significantly in the process to ruin the experience.
Dom
Mikipidia
ONLINE
BEOVOX141:
Where did you get that idea from Please elaborate
The 50’s have one dsp(chip) for both speakers in the master speaker. So the master does all the computation, processing and room comp and then sends the finished signal of to the slave speaker.
The 90’s have a dsp chip in both speakers and each one does it’s own calculation and dsp stuff.
I meant to say that it’s passive in a computational sense, not in the old fashioned sense.
Carolpa
ONLINE
Epsilon20:
And now the game changer, just a hypothesis: Epsilon20 wants to listen to jazz of the 50 of the last century. So he is buying new reissued albums.
In producing a reissue album, the original masters are digitalized, processed, etc. Finally a record is pressed.
But what is the point of this discussion (in this hypothesis) if he wants to experience vinyl if even the origin of the vinyl was digitalized!
BEOVOX141
Denmark, West
Silver Member
Mikipidia:
Based on the information in the technical sound guide, I find this very hard to believe.
Do you have anything that could support the claim?
poodleboy
Carolpa:
Epsilon20:
Amen, brother!!! If I remember correctly, the original demos of BeoLab 90 were done with Spotify tracks, and BeoLab 5 had their own demo CDs. I gave away many hundred records mainly because I was a partyophile vs an audiophile, and the warmth of my records (even with a nice system and many special masters) probably came from spilled drinks and cigarette smoke. Digital is good enough for me, and I only wish I could have a set of top BLs to prove it.
Mikipidia
ONLINE
Millemissen
Flensborg, Denmark
If someone wants ‘analog sound’, he should go to a venue, where music is played without amplification and processing.
If someone wants to listen to vinyl, he should do do so.....if he likes the sound and the handling of vinyl.
I guess listening on a set of the 50’es won’t diminish that experience for anyone.
Millemissen
Flensborg, Denmark
BEOVOX141:
Mikipidia:
Well, one is called master and the other slave.
DMacri
United States
DMacri replied on Sat, Jun 29 2019 4:24 PM
I think that means there is one DSP per speaker, not per pair, right?
Dom
BEOVOX141
Denmark, West
Silver Member
@ Miki
For starters.... From the white paper:
10.2.3
Digital Signal Processor Model Analog Devices ADSP-21489
Number 2  (my guess: two per speaker one for the room correction and one for the x-overs)
Instruction Rate 400 MHz Sampling rate 192 kHz (fixed)
Notes 32-bit floating point
I dont see anything in the whitepaper supporting you claim, actuality I see a lot contradicting it, but since you own a pair and I dont you could be right.
I would just like to see some hard evidence showing the slave does not have a DSP.
Have you read the whitepaper ?
Page 3 of 7 (92 items) < Previous 1 2 3 4 5 Next > ... Last » | RSS
