Beolab 5 - calibration again and again?
Not Answered This post has 0 verified answers | 6 Replies | 1 Follower
danielshen
danielshen posted on Mon, Jun 24 2019 4:13 AM
Dear all,
My beolab 5 has strange situation. It like lost the calibration data and ask for calibration again - with green light flashed intermittently ;
I think I just do the calibration last week. And now - 7 days later, when I start the beolab 5, the green light is flashed intermittently again. So I have to do the calibration again - this is very annoying. Can anybody help on this?
Thanks for your input!
Daniel
Michael
Sweden
Michael replied on Mon, Jun 24 2019 10:11 AM
Seems this is happening to more and more Beolab 5s. I wonder if there’s a small battery inside to keep the data. Like computers have batteries to keep their bios data sometimes.
oli
Southeast of France
oli replied on Mon, Jun 24 2019 11:45 AM
I noticed it can lose calibration when the device connected to the BL5 in SPDIF is switched on AFTER the BL5 are switched on
Beobuddy
Utrecht, The Netherlands
Beobuddy replied on Mon, Jun 24 2019 12:38 PM
Values are stored in a small eeprom which happens to be faulty at multiple bl5’s for the past time.
Calibration is done in 2 stages. The microphone comes out in 2 stages. When the mic doesn’t come out futher after the first stage, then the mechanism from the mic is faulty and the calibration isn’t finished and stored properly.
pauljrog
One of my Beolab 5 speakers every few months lost its calibration and the green light flashed. I had the eprom in the unit replaced and no problem ever since.
The eprom had to come from B&O headquarters as it needed special programming first.
danielshen
Do you think, if I have disconnect the power like 1-2 days, the EPROM will be cleaned or not - like reset?
pauljrog
No, my opinion is there is an eprom fault and will need replacing.
I dont think it will be an expensive fix. The eprom must be quite cheap to purchase and it took less than an hour to take out the electronics to swap out the chip.
There are specialist tools involved and you have to wear a static wrist strap.
I would get a specialist in.
Page 1 of 1 (7 items) | RSS
