Beovision 10 - how to remove back panel?
Not Answered This post has 0 verified answers | 3 Replies | 0 Followers
PatrickCG
PatrickCG posted on Wed, Jun 19 2019 8:51 AM
Hi everybody.
The fans on my BV 10-46 are getting too noisy, and regular hoovering doesn't seem to cut it anymore. I want to remove the back panel to inspect the fans properly, to determine whether to replace them or not. How do i do that?? BTW the TV is wall mounted, right side.
9 LEE
Eastbourne, UK
9 LEE replied on Wed, Jun 19 2019 12:53 PM
I think you disassemble these from the front.  Screen off, then you're looking at the internals...
Lee
Hiort
Sweden
Hiort replied on Wed, Jun 19 2019 1:21 PM
9 LEE:
Lee
Correct.
This is what it looked like when B&O retrofitted my good old BV10 due to heat related "click" noises from the chassi.
Everything done from the front.
PatrickCG
Okay, wow. Thank you.
Might just try cleaning the fans with compressed air to begin with Big Smile
Page 1 of 1 (4 items) | RSS
