Beovision Avant MK1 75 problem : no network...
Not Answered This post has 0 verified answers | 1 Reply | 0 Followers
sergi0
sergi0 posted on Sat, Jun 15 2019 10:30 PM
Hello !
I just spent a couple of hours try to identify a problem I had on my BV75 MK1.
When I powered on, instead of having a rapid startup (configure that way), it was the long one. When booting was finished, the TV asked me to enter everything to configure it, like when it was first installed. I must precise I had no power outage.
When I configure the network part (RJ45 on the wall), I notice there was not IP configuration , either when it was configure to DHCP or manually. Everytime I enter the parameters and store them, they don't persist.
As I have no network, I was not able to configure my PUC system (set top box and shield TV).
I did a couple of tests, change network cable, reboot everything, etc... During one reboot I can a message from the TV saying Recovery Menu (as pictured below.
I am not able to make a software update as I have no network, so I rebooted the TV. Besides the network, everything seems to work, but that is a really big problem for me.
Does anyone have a clue about what is the origin of the problem ? How can I force an update (I have the last version of the software in the TV) ?
Cheers,
Serge
sergi0
sergi0 replied on Sun, Jun 16 2019 8:03 PM
After some tests, it seems that the TV don't keep the configuration I enter as every time there is a cold startup it ask again for the entire configuration, as if it was new.
That doesn't sound good :)
Page 1 of 1 (2 items) | RSS
