A beomaster 6000
Not Answered This post has 0 verified answers | 82 Replies | 0 Followers
Craig
Yarm, United Kingdom
Silver Member
Craig posted on Wed, Jun 12 2019 7:05 PM
Following on from Peters BM8000 I have decided to take a look at this unit, came by way of Solderon (well I have to have something to occupy my time!) I'm not sure about these "modern day" pieces, prefer the metal and wood construction...and the micro-computer thing is also daunting, but they do look rather slick with the digital display.
sonavor
Texas, United States
This post I made last year shows what they look like taken apart. They are often heat fused shut so you have to break the seal.
-sonavor
sonavor
Here is another post on the dampers.
-sonavor
Dillen
Copenhagen / Denmark
Drill a small hole, inject grease while rotating the damper spindle, melt or glue the hole shut?
Craig
Silver Member
Craig replied on Thu, Jul 4 2019 12:32 PM
Thats quite a cracking bit of lateral thinking!
I'll try and drill a hole in what will be the top of the drum when it's in it's normal position to help reduce the possibility of leaking through the sealed up hole.
Craig
Craig
Silver Member
Ok.….here we go, bored a 2mm hole in the side of the damper drum carefully so as not to damage the internal turbine blades.
Craig
Silver Member
Managed to pump a reasonable amount into the hole before the air needed to be worked out in order to get more in, had I not been confident that there was still a fair amount in there anyway, because the paddle was still fairly stiff to rotate before I started, I would have been tempted to bore a second hole opposite the first to allow the displaced air to come out. I worked the air out with a wooden skewer and got a bit more in rotating the paddle all the time.
Craig
Silver Member
Sealed the hole up with a blob of plastic epoxy...…..the damping is increased by some 25% or so....not massively but as I said it was quite firm when I started....however it had bled over the internals so some grease had clearly been lost.
sonavor
My concern would be that the grease that liquified and leaked out was due to a deterioration of the product. I have seen that in a number of these devices and at the same time have some that are still perfectly intact. I think it is related to the environment the units have been exposed to. Similar to some Beocord 800x-9000 having worn belts while others have belts that have deteriorated into a black glue substance.
Hopefully your fix will work fine but I have to wonder about the state of the original damping grease that was still inside. In the end it isn't critical to the Beomaster working. You will just need to keep an eye on any leakage in the future.
Still, an interesting solution and I enjoyed watching the implementation.
-sonavor
Craig
Silver Member
Well.....pro's and con's I suppose....if things don't go well with the damper all I've done is drill a 2mm hole in the case and plug it up, time will tell. Got the control panel removed, awkward exercise depressing the tabs with enough force to release them but not too much to break them ;¬)
  • Filed under:
sonavor
Craig:
Haha, yes a lot of these repairs have pro's and con's.
If you think that panel was awkward wait until you remove the display piece to get to what is under that. It is another exercise in carefully navigating some plastic tabs.
-sonavor
BEOVOX141
Denmark, West
Silver Member
Craig:
Hi Craig
It looks like a delicate operation, how did you make sure chips from the drilling did not end up inside the damper?
The damper is a fascinating (and without a doubt expensive) piece of engineering, and very typical for the way B&O approached solutions, sometimes perhaps forgetting the benefits of the KISS principle.
Thanks for sharing the journey, I have a 6000 waiting to be brought back to life, so any tips and tricks a can collect before the surgery improves the chance for a speedy recovery of the patient. Big Smile
Craig
Silver Member
The answer to that is that I'm not sure no swarf made it into the internals, on the balance of probability some will have, will there be damage as a result possibly but I would say unlikely.
Seperated the pushbutton panel from the switch assembly...
Craig
Silver Member
Lots of dead skin cells and a crumpled corner of the sticky back plastic...….
Craig
Silver Member
As its the standby button I don't know if it was actually working prior to removal......the switch clicks in and out to applied pressure so I suspect it worked fine….however as I need to do something about it I eased it back to reveal the contacts beneath
Craig
Silver Member
the flexible contacts did have a small amount of dirty dust on them which cleaned right of with a cotton bud and some alcohol.....thing is do I really need to take them all out? I could do so and gold plate them, but is it really necessary? I will ponder for a while....I don't think it would do any harm.
Page 4 of 6 (83 items) « First ... < Previous 2 3 4 5 6 Next > | RSS
