Hello all,
I have been reading this forum for a while but as i am not even close to be an "expert" i wanted to ask two questions and i would appreciate a lot if somebody could answer. There have been similar discussions in the past but i was not able to fully answer my questions.
I have 2 B18s which were connected to the beo hub with my samsung tv (UE78KS9080) but at the end it didn't stop giving problems. Now i am thinking to move to the Core and potentially i am thinking of getting 1 B19, thus,
1) If i have the two B18s, 1 B19, can all these be connect edto the TV via the core? If so could you please indicate how? Would i need a splitter for the TOSLINK and if so which type? If for example in 1-2 years i want to have more B18s can these be connected to the same Core?
2) Could the B18, B19 be connected to some other wireless transmitter (alternative to core e.g. wireless amp?) and the TV and using which wires? and finally does the core now support IR?
I am sorry if my questions are a bit naive but any input would be precious.
Thanks in advance
nikokons:1) If i have the two B18s, 1 B19, can all these be connect edto the TV via the core? If so could you please indicate how? Would i need a splitter for the TOSLINK and if so which type? If for example in 1-2 years i want to have more B18s can these be connected to the same Core? 2) Could the B18, B19 be connected to some other wireless transmitter (alternative to core e.g. wireless amp?) and the TV and using which wires? and finally does the core now support IR?
BS Moment, BS Core, BS Ouverture, BG 4002, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
Thank you very much for your response it actually makes quite some sense. It is just i was not sure about the use of the transmitter. I thought that this could have been avoided....
One more question. Would you know if the core is IR sensitive or has become IR sensitive in order to avoid the use of the essence remote?
Once more thanks for your prompt response!
nikokons: One more question. Would you know if the core is IR sensitive or has become IR sensitive in order to avoid the use of the essence remote? Once more thanks for your prompt response!
You are welcome.
I'm not familiar with the Core IR setup, but you'll find a thread here: https://forum.beoworld.org/forums/t/26336.aspx?PageIndex=3
