Beo Core to Samsung TV
Not Answered This post has 0 verified answers | 7 Replies | 0 Followers
IndyBoy1007
IndyBoy1007 posted on Sun, Jun 9 2019 10:07 PM
Hi folks,
Looking for a bit of help here have a Beo Core linked to BL8000s works perfectly with it wired to wifi router.
Got a samsung TV recently 50NU7020K - hooked up core to TV by optical and nothing plays from the telly. Changed settings to select optical but still nothing although the TV sound does go silent.
Bit stuck here help very welcome arghh! Stuck listening to samsung sound from the telly with a pair of BL8000s sat idly by :(
new to the game - awaiting my first BL 8000s MK1 Lets have a Party !!!
Millemissen
Flensborg, Denmark
Setting the output format of the tv to PCM should help.
See also here: https://us.community.samsung.com/t5/4k-8k-and-Other-TVs/Optical-audio-output-not-working/td-p/214630/page/3
IndyBoy1007
Hi thanks for the tip but no luck
I've also selected Optical from the Core app and realising the optical cable doesn't seem to attach into the Core correctly
I have this - https://www.google.com/aclk?sa=L&ai=DChcSEwiEo_rN5OHiAhWYrO0KHYqECIYYABAHGgJkZw&ae=1&sig=AOD64_282eI0q1Kj0yw7Ad9AujZtA8-R8A&ctype=5&q=&ved=2ahUKEwi4svTN5OHiAhXiRhUIHbv9D9YQwg96BAgKEAo&adurl=https://www.amazon.co.uk/deleyCON-Optical-Digital-Toslink-connectors-Black/dp/B00R7OG1LO/ref%3Dasc_df_B00R7OG1LO/%3Ftag%3Dgoogshopuk-21%26linkCode%3Ddf0%26hvadid%3D205215094696%26hvpos%3D1o1%26hvnetw%3Dg%26hvrand%3D12749338511719123308%26hvpone%3D%26hvptwo%3D%26hvqmt%3D%26hvdev%3Dm%26hvdvcmdl%3D%26hvlocint%3D%26hvlocphy%3D9046974%26hvtargid%3Dpla-423654335030%26psc%3D1
Do I need this instead - https://www.google.com/aclk?sa=L&ai=DChcSEwich9qc5eHiAhXmve0KHYfQDCEYABAUGgJkZw&ae=1&sig=AOD64_3rs5PjJon1qr-J5IHf1kjsXLIt5Q&ctype=5&q=&ved=2ahUKEwip2cuc5eHiAhWqUxUIHaavADwQwg96BAgKECU&adurl=https://www.amazon.co.uk/FosPower-Toslink-Digital-Connectors-Strain-Relief-Gold/dp/B00T8HWUVS/ref%3Dasc_df_B00T8HWUVS/%3Ftag%3Dgoogshopuk-21%26linkCode%3Ddf0%26hvadid%3D205210909091%26hvpos%3D1o5%26hvnetw%3Dg%26hvrand%3D15915185552916622419%26hvpone%3D%26hvptwo%3D%26hvqmt%3D%26hvdev%3Dm%26hvdvcmdl%3D%26hvlocint%3D%26hvlocphy%3D9046974%26hvtargid%3Dpla-312488743612%26psc%3D1
Thanks again!
henrik
Sweden
henrik replied on Tue, Jun 11 2019 9:14 PM
IndyBoy1007:
Yes, since the optical input of the Core is a mini-Toslink (the regular-size Toslink on the Core is an output, not an input).
henrik
Sweden
henrik replied on Tue, Jun 11 2019 9:17 PM
(the Core manual could be a bit clearer in this matter, it does not explicitly state that a mini-Toslink is needed)
IndyBoy1007
Ordered! Thank you - having never used optical ever before I didn't know, fingers crossed :D
Rob - Danish AV
Melbourne
I have a client with a similar setup. If connected via Optical, the only volume control will be via the Core? the client wants to control volume from the TV remote, a 3.5mm is the other option?
henrik
Sweden
henrik replied on Sat, Jun 15 2019 9:20 AM
Rob - Danish AV:
That depends on the TV. My the volume control of my Samsung does not affect the optical output, so in that case the Core's volume control is the only option, but other TVs may have different features.
So analog 3.5 is the safest bet if volume control from the TV is needed.On the other hand, there's no big loss in that solution unless your client has, let's say, beolab 50s and golden ears.
Page 1 of 1 (8 items) | RSS
