Beosystem 3 mk1 with Dvi output No picture on Samsung Tv
Not Answered This post has 0 verified answers | 9 Replies | 0 Followers
jambo81
jambo81 posted on Tue, Jun 4 2019 4:23 PM
Hi Guys,
looking for some help Please, i have just purchased a 2nd hand Beosystem 3 from eBay,
i cant get any picture on My B+O TV or my Samsung TV, there is a green led light on back were power cord
is but it lights up for about 5 seconds and goes off, is that normal ? i have the system connected via the dvi port 1 with HDMI converter , but cant get video showing, i also tried on my PC monitor to no avail,
i have been pressing buttons on my Beo 4 remote for hours, can any one shed some light on this, as i don't
know whether the unit is faulty,
Any Help Much Appreciated Confused
BEOVOX141
Denmark, West
Do you have an IR eye connected ?
jambo81
Hi,  no nothing connected other than Blue-ray player via Dvi to HDMI.
jambo81
BEOVOX141:
BeoIce
Recklinghausen, Germany
Without an ir-eye you can't control the BS3.
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
jambo81
Hi would any  ir-eye do or is there a specific one for it ?
cheers
BEOVOX141
Denmark, West
This one!
Image result for olufsen ir eye bs 3
jambo81
Thumbs Up Thanks for your help
DMacri
United States
I’ve had success with one from a VX5000, so you may be able to use older models too.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
DMacri
United States
Once you get the IR sensor installed, you may have to use the reset command from the Beo4 to put the BS3 in safe mode until you reset the output resolution to one your tv will accept.
Dom
Page 1 of 1 (10 items) | RSS
