Beosound 3200 aerial fittings.
Not Answered This post has 0 verified answers | 3 Replies | 1 Follower
max65special
max65special posted on Fri, May 31 2019 2:41 PM
The correct aerial fittings on my Beosound 3200 are missing. I have looked on Ebay & the fittings that are present are
TV/FM COAXIAL CABLE CONNECTOR FEMALE PLUG
I tried fitting a standard
COAX FEMALE SOCKET TO F PLUG ADAPTOR CONNECTOR CONVERTER SATELLITE
but this is too big for the socket. The part for the fitting to push in to is present.
Can someone please tell me which type of aerial fittings I need?
Thanks.
joeyboygolf
Ely, Cambridgeshire, UK
You need a coaxial cable joiner. ie. two female sockets back to back.
No need to type so loud, I heard you !
Regards Graham
max65special
The thread is on the ouside of the fittings not the insided so the fittings you suggested can't be screwed in, the new fittings are also too big for the socket. The fittings currently present are for a bare end aerial.
Pat
Pat replied on Mon, Jun 3 2019 1:58 PM
Take off the f-type and put the “standard” female plug, simple
Page 1 of 1 (4 items) | RSS
