UHD with Beovision Avant 55 1st Gen.
Not Answered This post has 0 verified answers | 12 Replies | 2 Followers
MircoHH
Germany
MircoHH posted on Sat, May 25 2019 7:06 PM
I have a SKY Q UHD Receiver and connected it to the HDMI1 Port. The Beovision recognized the UHD Signal correct, but I don't see any differences between Full HD and UHD. The Source is a UHD Source.
When I check the signal information in the service menu, the input resolution is 3840p, but the output resolution is only 1920p.
Can anybody check if this is normal?
thanks
Mirco
MircoHH
Germany
Service Menu 1
Aussie Michael
Melbourne, AU
Hi Mirco,
I read your post and thought I would check what my settings are too
I have 2 4K products
- HDMI 1: Xbox set to 8 bits so it can do the 4K SDR
- HDMI 2: Apple TV 4K
I'll post pictures of what they are
Aussie Michael
Melbourne, AU
HDMI 1
Aussie Michael
Melbourne, AU
HDMI 2
poodleboy
How do you acquire the "signal information" display on that TV? Thanks
BEOVOX141
Denmark, West
Silver Member
Its in the customer service menu.
OPTIONS, RED ARROW, GO
poodleboy
@ BeoVox141, Thanks for that. Informative and I now know why I can't tell the difference in PQ on my mate's TV.
His Avant 1 also receiving 4k and displaying 1080p, while on Roku 4k. HDCP is correct at 2.2.
Any ideas?
MircoHH
Germany
Hi Aussie Michael,
you have exactly the same problem like me. The AVANT gets 4K Input but only display 1920x1080p. HDCP and HDM1 Connection is correct.
mjmedlo
From what I understand the menu is in 1080p
But the image is 4K
That’s what I have been told anyway.
poodleboy
mjmedlo:
But the image is 4K
Part of me says that makes no sense Confused The other part says it makes perfect sense Wink Picture looks better already Smile
Thanks for your insight.
w5bno123
London
w5bno123 replied on Sun, May 26 2019 10:36 PM
mjmedlo:
But the image is 4K
This is 100% correct. I have an Avant 55 MKI with Sky Q and you’re able to see the difference when UHD is broadcast
Aussie Michael
Melbourne, AU
I also heard that about the menu before not being 4K , so i purposely checked when it was on a source playing 4K content.
I believe it is showing at 4K even if that menu says different, because even on the Xbox when i change from 4K to 1080 you can see the difference, I believe.
My HDCP says NULL on one source and the other says 1.1.  Not sure what that really means
Page 1 of 1 (13 items) | RSS
