Turn on the Beovision with a network command
Not Answered This post has 0 verified answers | 6 Replies | 1 Follower
doun
doun posted on Wed, May 22 2019 11:29 AM
Hello,
I try to turn on the Beovision 11 through the network with a put request and json format. I am able to put it into standby mode but I don't know the command to turn it on.
Please find the command to turn it off : self._postReq('PUT','BeoDevice/powerManagement/standby', {"standby":{"powerState":"standby"}})
But I don't know the command to turn it on. Do I need to activate a source?
Can someone help me to find the solution?
ngnear
ngnear replied on Wed, May 22 2019 3:49 PM
This may be useful
https://github.com/PolyPv/BeoRemote/blob/master/BeoRemote.txt
Tim
Opman
Wilmslow, Cheshire
Opman replied on Wed, May 22 2019 9:38 PM
In Network settings of the TV you need to switch on WAKE ON LAN to be able to switch TV on via network.
Aussie Michael
Melbourne, AU
Interestingly if you have a BV14 - there is no Wake on LAN command, only a Wake on WLAN
But as you have a BV11 i'd agree (just letting you know incase you change your TV)
doun
doun replied on Thu, May 23 2019 7:32 AM
Thanks for your answer. This option is already set on my TV. I tried to set a new source via the network (as I did with the remote control)to wake up the TV but it didn't work. I think there is another command but I did not find it...
PaulGiles
Could not get my BV11 to wake on LAN, wired or wireless.
Integrated core and it comes on as soon as you connect to the core.
doun
doun replied on Mon, May 27 2019 6:26 AM
I found the solution. You need to send a magic number to wake up the BV11 and then you can send another command.
send_magic_packet(MAC,ip_address='192.168.0.255',port=9) where MAC is  the MAC address of the TV.
Best regards and thanks for your help.
Page 1 of 1 (7 items) | RSS
