Beosound 9000 Starup volume
Not Answered This post has 0 verified answers | 1 Reply | 1 Follower
kallem3
kallem3 posted on Tue, May 21 2019 10:20 PM
Hello everyone, I thought I had it already some years back but seems I lost it - how can I adjust the startup volume of the Besound 9000, so that its not that loud when starting up?
many thanks, Stefan
Bill Briscoe
Chicago, IL USA
if you use the keypad, select all the settings you want, including volume, and then select ok, then ok again. The settings will be stored for the next time you use it.
Good luck,
Bill
Page 1 of 1 (2 items) | RSS
