Moment network
Answered (Verified) This post has 1 verified answer | 5 Replies | 1 Follower
Andrewharvey
Andrewharvey posted on Sat, May 18 2019 10:51 PM
Hi
Having issues connecting my moment to a hardwired rj45 network cable rather than wifi
Are there settings that i need to alter - i only see the available wifi networks to connect to?
Thanks in advance Andrew
Carolpa
Verified by Andrewharvey
Andrewharvey:
How is the DHCP in the Moment and in your network set?
Fansastic
The Netherlands
Hi, when you hardwire the moment it autodetect the network. Wifi is still needed for the jukebox to communicate with the soundheart, thats why you still have to give in a wifi connection. You can see in the beotool that your moment is wired
Hope this helps
mbolo01
Annecy - France
mbolo01 replied on Sun, May 19 2019 10:51 AM
If the SoundHeart is wired, the ethernet connectivity has priority over the wireless.
The Jukebox is wireless only, 2,4GHz band only.
BS Moment, BS Core, BS Ouverture, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, H5, TR1
Carolpa
Andrewharvey:
Andrewharvey
The use DHCP setting is on
Is this correct?
mbolo01
Annecy - France
Andrewharvey:
Maybe you can provide us more details ? To what kind of equipment have you connected the SoundHeart via Ethernet? Do you have a mean to check if the equipment port you connected the SoundHeart is up and running? If not have tried another cable ? Etc ...
Page 1 of 1 (6 items) | RSS
