My dealer showed me how to mount an ATV4/4K inside a BV11
This post has 21 Replies | 2 Followers
Dyssegaard
Copenhagen, Denmark
Posts 190
Dyssegaard Posted: Wed, May 15 2019 3:49 PM
For some time I’ve had an ATV3 mounted inside my BV11 (my wife doesn’t like external boxes).
I would like to have an ATV4K instead, but there wasn’t enough space for it (it’s 12 mm thicker than the ATV3), so I asked my local B&O dealer what to do. He showed me, that the BV11 was actually preparred for it, but it required that a small piece of the inside cabinet was removed.
Before removal:
After removal:
This piece was removed:
And now the ATV4K fits nicely:
PS: The PUC table for the ATV4K is great. It has direct access to Home screen and Airplay speakers Big Smile
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K, Bedroom: Beovision 11-40, AppleTV 4. Home office: Beolit 12, Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
seethroughyou
UK
Posts 763
I agree with your wife that external boxes are ghastly. Good job. Thank you for sharing. I’ve wanted a Bv11 for years but my wife has gone the Costco route sadly. The ability to hide boxes away is a strength with this TV.
Hiort
Sweden
Posts 2,482
Hiort replied on Thu, May 16 2019 8:53 AM
Nice tip!
Is that a 46" or 55" you have there?
Does it matter for the space available?
Dyssegaard
Copenhagen, Denmark
Posts 190
Dyssegaard replied on Thu, May 16 2019 11:13 AM
Hiort:
Nice tip!
Livingroom: BL3, BL11, BV11-46 Kitchen : Beosound 1 GVA, Beocom 2 Bathroom : M3 Library : A6, Beocom 6000 Bedroom : M5 Office : Beocom 2 Travel : Beoplay E8 2.0, Beoplay P2
It’s a 40” so I guess that there won’t be less space in the bigger models.
The ATV4/4K has a depth of 35 mm, so it should be easy to verify in advance if it will work.
Hiort
Sweden
Posts 2,482
Hiort replied on Thu, May 16 2019 3:31 PM
Got inspired and did the same on my BV11-46.
Worked very well:
Now the cabinet under the TV is empty Smile
hostler
Posts 47
hostler replied on Thu, May 16 2019 4:16 PM
You win at living rooms Smile
Hiort
Sweden
Posts 2,482
Hiort replied on Thu, May 16 2019 4:51 PM
hostler:
Thanks Smile
Dyssegaard
Copenhagen, Denmark
Posts 190
Hiort:
Worked very well:
Very nice Big Smile
PS: My answer rgd. size (my BV11 is 40 inch) seems to have been blocked by the moderator. I don’t know whySad.
Reto
Zurich
Posts 43
Reto replied on Sun, Sep 8 2019 1:08 PM
Cool!
What is the piece made of? Plastic?; Hence you can easely take it off?
Hiort
Sweden
Posts 2,482
Hiort replied on Sun, Sep 8 2019 3:05 PM
Reto:
Cool!
Yep, plastic
Aussie Michael
Melbourne, AU
Posts 3,438
I find that the ATV4K runs hotter than previous gen (fans etc)
Would it pay to turn the ATV 4K around so the bottom (fans) face outward ?
Even though the BV11 can’t handle 4K did you install the 4K version because it’s a quicker device ?
Hiort
Sweden
Posts 2,482
Hiort replied on Mon, Sep 9 2019 12:54 PM
Aussie Michael:
My install was the “non 4K” version. The 4K have small slots in the bottom to ventilate the casing. If installed like this it’s recommended to mount the ATV 4K so that it can ventilate.
Dyssegaard
Copenhagen, Denmark
Posts 190
Aussie Michael:
I had to refit the PUC cable because the ir-sensor location of the ATV 4K was different from the ATV 3 previously installed. At the same time I turned the ATV 4K so the fans are now facing outward. Everything works perfect now.
My dealer recommended the 4K version due to the better performance for a very small additional price compared to the HD version.
Aussie Michael
Melbourne, AU
Posts 3,438
Great news
I also found that the puc cable is mounted on the left side of the ATV4K
Ever since I changed that I was happy to works well.
The ATV4K still doesn’t turn off though when I turn off my BV14
kuyttendaele
Posts 558
Aussie Michael:
Great news
Same thing in my BeoVision 14-40. A bug in the PUC-table I guess.
Karel.
Aussie Michael
Melbourne, AU
Posts 3,438
kuyttendaele:
Karel.
What I worked out today is that there was under PUC management that there was an update the the ATV4 PUC
So I updated it.
I will see if that fixes.
As a workaround you can press LIsT and power and it shuts off. Not sure if I tried that before the update or not.
Millemissen
Flensborg, Denmark
Posts 13,119
ONLINE
Always use the right PUC
Aussie Michael
Melbourne, AU
Posts 3,438
Millemissen:
We are assuming the ATV4K is the 4th gen
Millemissen
Flensborg, Denmark
Posts 13,119
ONLINE
Sure!
kuyttendaele
Posts 558
I'll update my PUC tonight... But I'm also running the beta of tvOS... so probably 2 issues at once... tvOS should probably be out of beta beginning October (or at the latest 1Nov when AppleTV+ launches)
Karel.
OlivierC
Posts 57
OlivierC replied on Fri, Sep 13 2019 7:11 PM
Same issue here with BeoPlay V1 and ATV3: PUC is the correct one and it seems to be updated but it is not switching off.
Olivier
Aussie Michael
Melbourne, AU
Posts 3,438
It seems the update didn't fix the issue of the power for me.
I even re set up the HDMI from scratch but no beuno
Page 1 of 1 (22 items) | RSS
