Beovision 10, 11 or 7
Not Answered This post has 0 verified answers | 13 Replies | 0 Followers
Andrew
Frinton, UK
Andrew posted on Thu, May 2 2019 2:08 PM
Hi
I'm looking to get either a Beovision 10, 11 or 7 - are there major differences and anything I should look out for - looking to spend upto £1.5k and wanted one with low usage - although no one on ebay seems to say how many hours/days they've had. I like the design of the 7, but figiured the 11 is newer and should be better - looking for either 40 or 46" - I only watch DVDs or Apple TV no live TV so not interested in any smart functions.
Hiort
Sweden
Hiort replied on Thu, May 2 2019 4:15 PM
I would say that the BV11 is the most sensible buy. There was a thread in the forum not long ago that included advice on what to look for when buying a preowned BV11.
They may however be a bit more expensive than the budget you mention.
I have a BV11 - 46 and are still very happy with it.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2  Library: A6, Beocom 6000 Bedroom: M5, Essence remote  Travel: Beoplay E8 2.0, Beoplay P2, Beoplay Earset
Hiort
Sweden
Hiort replied on Thu, May 2 2019 4:16 PM
Here is the thread I mentioned.
Andrew
Frinton, UK
Thanks Hiort - I remember reading that - I looked at the manuals for both and the 11 doesn't have masterlink? or RF out for a link TV? Does the 10 have RF out do you know - I couldn't see it
moxxey
South West, UK
Andrew:
Hi
I've owned all 3! The only thing I miss with the BV10 is the superb bright orange fret. The BV11 is an upgrade and should always be considered.
Personally, I think the 7 looks a bit dated now and the BV11 looks timeless. I'd go with the 11 every time, but you might struggle to get a 46" for £1.5K.
PaulGiles
Yep. 11-46, great TV. Even the MK1 is perfect
vikinger
Vestri Kirkjubyr, UK
I have a BV11 40:Mk1. Superb TV, with, in my case, built in Sat tuner and recording hard disk module.
I was initially disappointed that it couldn't directly use Masterlink, but I kept it as a standalone with a Cambridge DVD player. My Masterlinked systems are running independent of the BV11 using a BV5 and BC2 as the master units.
The smart TV functions are not worth worrying about, although the BBC iPlayer works well. B&O never got around to accommodating other streaming / catch up systems in the U.K. like ITV, Channel 4, 5 etc etc. For that you'll need an Apple TV or equivalent.
Graham
Hiort
Sweden
Hiort replied on Thu, May 2 2019 8:53 PM
Andrew:
No Masterlink. I used to have a Nl/ml converter when I still had Masterlink devices.
No RF out.
Generally I think RF out would provide a rather bad picture quality with today’s standards
Hiort
Sweden
Hiort replied on Thu, May 2 2019 8:54 PM
Andrew:
Yes it has
Schlaumeier
Go for a BV 10. The last B&O without this Smart-TV-***.Smile
Beste Grüße / Best regards
Schlaumeier
Setup Livingroom: BeoVision 10-40 and 10-32, BeoLab 6000 front, BeoLab 4000 rear, BeoLab 11, Ouverture, Apple TV 2 & 4, Airport Express, 6 x LC2.
Other Rooms: 3 x BeoSound 8, BeoVision 8-26, MX 4002, 2 x Keyring, 2 x Beolit 15, A1, Airport Express, 4 x Beo4, 2 x Beocom 5
DMacri
United States
DMacri replied on Mon, May 6 2019 11:13 PM
Schlaumeier:
And the last BeoVision with Masterlink, if that matters to you.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, and ambio
Andrew
Frinton, UK
Andrew replied on Tue, May 7 2019 11:21 AM
Thanks for all the replies - will save up for a BV11 - I think I can do without masterlink as the bedroom TV has it's own Apple TV connected and I have a beolink active in the room for music.
Andrew
Frinton, UK
Siggi
Silver Member
Siggi replied on Tue, May 7 2019 2:22 PM
Good choice...the Sound of the build in Speakers are much better in the 11.
Greetings Siggi
Page 1 of 1 (14 items) | RSS
