din connector
Not Answered This post has 0 verified answers | 3 Replies | 1 Follower
ar2be
ar2be posted on Wed, Apr 24 2019 3:04 AM
Hi All,
I have a beogram 3000 model 5231 with rca jacks on it. I would like to go back to what I am guessing would be a 5 pin din connector for it. What posts do I need to use to match the plug in a beomaster 1900?
Thanks, Bob
sonavor
Texas, United States
This page on the Beolover Blog shows a good diagram on the phono wires to for a Beogram DIN plug. Along with the RCA jacks is there a separate chassis ground wire?
-sonavor
ar2be
ar2be replied on Thu, Apr 25 2019 4:11 AM
Yes I do have a ground wire from the turntable to the ground post on the beomaster 1900. I do have to do some more investigating as I only have one channel working at this time. Do you know if there is a way to check the cartridge function with a multimeter?
Thanks,Bob
sonavor
Yes you can make some measurements using a DMM. Here is a short description from the Shure cartridge manufacturer.  I have never tried doing measurements that way however.  I always test cartridges using a Beogram turntable, a test record and an audio analyzer.
I thought you were wanting to know about replacing the phono cable RCA jacks with a proper DIN plug for a Beomaster 1900.
Getting back to that question you will have all the wires you need from the two RCA jacks and the chassis ground wire to put together the 5-Pin DIN plug. Note: Some Beomaster 1900 units come with a 7-Pin DIN plug but that doesn't matter. The number 6 and 7 pins aren't used by the BM1900 and the 5-Pin DIN plug fits in the 7-Pin DIN socket no problem.
-sonavor
Page 1 of 1 (4 items) | RSS
