Moving from Moment to Core?
Answered (Verified) This post has 1 verified answer | 25 Replies | 1 Follower
Hiort
Sweden
ONLINE
Hiort posted on Wed, Apr 10 2019 1:15 PM
Started to think about replacing my Moment with a Core.
Main reason for this is to get something more future proof and the fact I do not use the Moment screen that much anymore but rather the app.
Some more benefits:
  • The levels on the line in can be adjusted (benefit for my connected Beogram)
  • Better sound (?)
  • Chromecast built in
  • Future proof (mentioned above)
  • Hideaway box
  • Airplay 2
Key thing for me is that I can integrate Core with my BV11 exactly in the same way as I have done with Moment. That is using the speakers connected to  BV11 as speaker groups for e.g Music and Radio.
Anyone that can confirm that?
Dyssegaard
Copenhagen, Denmark
Verified by hostler
hostler:
... The big difference is that when integrated, the CORE is removed from the App product view - so you can't get back to it's setup/config screens - eg. to change the line-in sensitivity. ...
You can access the Core setup from the App via the front page by selecting the settings “wheel” - see screen shot - and then “Products”. Select the Core and you can then select the configuration pages.
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K, Bedroom: Beovision 11-40, AppleTV 4. Home office: Beolit 12, Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Millemissen
Flensborg, Denmark
https://bogo.custhelp.com/ci/fattach/get/1304261/0/filename/Multiroom+-+october+2017+-+PDF+handout.pdf
I wonder how the rew remote will act in the integrated setup?
Hiort
Sweden
ONLINE
Hiort replied on Wed, Apr 10 2019 1:29 PM
Millemissen:
From the PDF you linked, I take it that the answer to my question is "yes".
Regarding your question regarding the remote, I guess it should be able to talk to the Core as with all other audio products. Probably the interaction with BV11 will be zero, since BV11 does not work with any bluetooth remote today.
Millemissen
Flensborg, Denmark
But if it talks to the Core, which turns on the tv........
But you are probably right - it will be rather limited.
Hiort
Sweden
ONLINE
Hiort replied on Wed, Apr 10 2019 1:50 PM
Millemissen:
Yes, that is my thinking. It only talks to the core and trigger e.g source. Then the Core does its thing (like waking up the TV ).
Can core handle the "old" Beoremote One or does it have to be the Bluetooth version?
Millemissen
Flensborg, Denmark
There is a version with support for a connected ir-eye.
I guess that new remote would display metadata and more from the Core, the regulation of the volume would have to happen with the ir remote via the BV11.
We will see, if we could live with that?
Dyssegaard
Copenhagen, Denmark
I have a Core integrated with my BV11 and I also have a Beoremote One BT.
You should be aware of the following for an integrated setup:
- Chromecast is not available.
- No BT pairing between the Core and the remote. You must use ir commands via the BV11 to control volume, source etc.
- The B&O app has a lot of cosmetic errors when using the integrated BV11/Core.
seethroughyou
UK
Silver Member
1.
This is very interesting as I had the Core but it had problem after problem with the software and I found I didn’t like using or holding an iPad. There is something about the Moment tablet that I like and the simpler layout on the Moment’s screen. Am interested in observations from those who have used both whether they be dealers or regular customers like me.
2.
You also don’t get Pattern Play on a Core.
AnalogPlanet
Vienna, Austria
...and Core has no WISA capability. :/ That's what's a showstopper for me.
Hiort
Sweden
ONLINE
Hiort replied on Wed, Apr 10 2019 4:03 PM
Dyssegaard:
Specification says “Chromecast built in” and I have seen videos where the core is added to Google Home.
Hiort
Sweden
ONLINE
Hiort replied on Wed, Apr 10 2019 4:04 PM
AnalogPlanet:
True, but it’s not important for me.
Duels
England
Duels replied on Wed, Apr 10 2019 4:10 PM
AnalogPlanet:
Just add a transmitter 1.
Dyssegaard
Copenhagen, Denmark
Hiort:
Yes - but in an integrated setup it is disabled!
I think it’s because the integration uses the nl protocol so it’s similar to nl multiroom.
For Airplay 2 to work in the integrated setup, multiroom for Airplay has to be selected on the Core, but there is no possibility to enable Chromecast for multiroom in the Core setup.
Hiort
Sweden
ONLINE
Hiort replied on Wed, Apr 10 2019 5:07 PM
Dyssegaard:
Hmm.... that was one of the main reasons for planning a swap to Core.
AnalogPlanet
Vienna, Austria
Duels:
Well, thats an extra box to hide, more cables, extra power socket to find and 400EUR to add.
I always wondered what made B&O adopt WISA, and then drop it on its one single available music system? While all speakers - both standalone and integrated ones have it.
Page 1 of 2 (26 items) 1 2 Next > | RSS
